front prop shaft on a sj 413 been converted to a 417
Shawboy
Re: front prop shaft on a sj 413 been converted to a 417
Post by Shawboy » Sat Jan 18, 2014 2:02 pm
yeah both props snapped
Eat! Sleep! Offroad! Fix! Repeat!
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Ladaman
Post by Ladaman » Sat Jan 18, 2014 2:15 pm
Shawboy wrote:has anyone modified and fit Toyota props , I think they will need shortening and will need adapters fitting but maybe I should try this route
I've just picked up some Toyota LJ70 (I think) props. I got them from a mate who had quite a radical SJ. Apparently they have a much larger operating angle on the UJ's than the Suzuki ones, and they are supposed to be much stronger, not that I have broken any in the past. I think they will need altering for length and adaptors making, but they will be going on.
Have you got a pic of the failed shafts? Where have they broken, because it does seem a strange thing to be braking shafts so often.
Shawboy
Post by Shawboy » Sat Jan 18, 2014 3:52 pm
ill post pictures later as the failed props are at my garage. Are you selling them? I have a guy who makes adapter plates and can shorten them. If the angles are better then I think its the route I need to go down.
Ive heard people mention bam bam bars? is this just for spoa?
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Post by ScottieJ » Sat Jan 18, 2014 6:34 pm
You don't have enough lift to need spacers, the slip yoke was probably bottoming out with the spacers fitted.
Your Tcase hasn't been moved so the engine swap will make no difference .
Shawboy
Post by Shawboy » Sat Jan 18, 2014 8:13 pm
cheers scottie ive bought some more props so ill try them without the spacers and if that don't work ill go for the strengthend ones.
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
