front prop shaft on a sj 413 been converted to a 417
Shawboy
Post by Shawboy » Sun Jan 12, 2014 2:05 am
is there any other prop shafts that fit a 413 when its had a body lift? or is it just the 413 with a spacer?
Eat! Sleep! Offroad! Fix! Repeat!
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Ladaman
Re: front prop shaft on a sj 413 been converted to a 417
Post by Ladaman » Sun Jan 12, 2014 10:51 am
A body lift shouldn't alter props.
A suspension lift may mean a prop adjustment. Upto about a 1" spacer seems to do the trick for most, or have you gone radical?
Shawboy
Post by Shawboy » Sun Jan 12, 2014 4:13 pm
its got a 4 inch body lift I have spacers fitted but still grinds and recently snapped. im just wondering difference in the 410 prop and the 413 also if any other props fit it any better?
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Post by twiss » Sun Jan 12, 2014 4:40 pm
I think one of the types of 410 prop is shorter than other props but I'm not 100% on that
Post by dan_2k_uk » Sun Jan 12, 2014 4:46 pm
The are longer 410 props. As said a body lift shouldn't affect props at all unless the transfer box has been "tucked"
Shawboy
Post by Shawboy » Sun Jan 12, 2014 5:54 pm
what you mean by tucked I have a carlton gear box the engine is the Isuzu 1.7td. I had to add a spacer on the prop but it only lasted 12 hours offroad before it snapped. if this is the case maybe I need to buy a few in
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Ladaman
Post by Ladaman » Sun Jan 12, 2014 5:58 pm
It's a good point raised by Dan.
I think he is suggesting the transfer box might be lifted in the chassis, or tucked out of the way. If it has been lifted out of the way the prop angles would increase, and make the chances of them binding be greater.
Where did it snap?
Shawboy
Post by Shawboy » Sun Jan 12, 2014 6:13 pm
my prop angle is far from straight so im gathering the transfer box has been raised.
would I be better with the 410 front prop on my 413. Ive heard someone say theres another make prop you can use nut I don't know were I have read this.
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
Post by ScottieJ » Sun Jan 12, 2014 6:19 pm
410 props are longer than 413 and samurai props by around 1"
Any chance you can post some pictures of the tbox mounts, prop angles etc? How much of the slip home on the props is showing.
You can get away with around 3" lift (either suspension or a combination of lifted Tbox and suspension etc.) without using spacers.
Shawboy
Post by Shawboy » Sun Jan 12, 2014 6:28 pm
i've just tried taking a few photos but its pitch black I will get them posted up in morning. is there a right and wrong way to fit the prop as well? as the shorter side was closer to my transfer box?
1.7td
Suzuki Samurai
200tdi Radiator
4" body lift
33" Anaconda Tyres
Carlton gearbox
anus wheel arches
Tape Player
