SJ410 - turbo diesel conversion
samus II
Re: SJ410 - turbo diesel conversion
Post by samus II » Fri Dec 12, 2014 2:30 pm
..just clicked that it's /not/ a turbo motor you've put in. whoops haha
'91 samurai - samus II - currently undergoing bottom-up restoration/turbo diesel swap
'02 Subaru WRX (350awhp)- rexie - currently undergoing ej207/6mt swap
Husky
Post by Husky » Fri Dec 12, 2014 10:42 pm
samus II wrote:..just clicked that it's /not/ a turbo motor you've put in. whoops haha
sorry? its a 1.5 turbo diesel isuzu engine ive put in.
Post by ScottieJ » Fri Dec 12, 2014 11:36 pm
samus II wrote:How does the sj gearbox hold up with the strain from all the extra torque?
All the extra torque? There isn't much ;)
The X15dt (t4ec1) is 66bhp and 97lbs-ft
The vitara G16 16v that is a very common swap is 95bhp and 97lbs-ft and the transmission holds up fine.
Post by twiss » Sat Dec 13, 2014 1:08 am
ScottieJ wrote:[
Apart from it seems to go through cheap clutches rather quickly ;)
Post by ScottieJ » Sat Dec 13, 2014 1:10 am
And that's why I don't fit cheap clutches :lol:
Rhinoman
Post by Rhinoman » Sat Dec 13, 2014 9:47 pm
twiss wrote: Apart from it seems to go through cheap clutches rather quickly ;)
That reminds me of this page:
http://www.nitromax.nl/SAMENGINESWAP.HTM
Husky
Post by Husky » Wed Feb 04, 2015 9:10 pm
Update! got some more work done to here.
Drained the petrol from the tank and hooked up the fuel lines, primed the system and now have it running straight from the tank :) ive got a fuel filter from a diesel fiesta to mount and plumb in as its running a little inline filter that allows fuel to run back into the tank so you have to prime it every time.
Ive got the glow plugs hooked up to a motorbike starter solenoid on a little button in the cab which seems to be working spot on. luckily the temp sensor on the isuzu engine is compatible with the sj clocks so thats a bonus.
ive got some thick gauge cable and battery lugs so can hook up the alternator soon.
i went for a clio/ kangoo radiator as both ports are on the right which i need for the isuzu engine but its a tad too big so im going to go back to the standard rad and stick a nice big fan on it.
just odd little bits now and then its ready to go for mot, needs 2 little patches of welding but nothing major.
the only problem im having is the top coolant flange is touching the bulkhead and there isnt really enough room to cut a hole in it as the heater is right behind it so ive bought a thermostat housing off an astra DTI which comes out at more of an angle so that should hopefully sort that problem out, as you can hear on the video the engine vibrates through the bulkhead.
Some pics.
Click Here for Youtube Video
Post by Anton » Wed Feb 04, 2015 9:52 pm
Top work!
You'll have 'er out and about soon!
Husky
Post by Husky » Sat Feb 07, 2015 10:01 pm
Anton wrote:Top work!
hopefully, want to get it ready for mot soon but been saying that since christmas lol.
Husky
Post by Husky » Sat Feb 07, 2015 10:02 pm
the astra water manifold flange thingy came through today, looks like it should clear nicely.
