Virtual lift Q&As
- turbo-tom
Re: suzuki steve's 410 build
number five work very well if your too lazy to do a virtual lift when running 31's
- suzukisteve
- Suzuki Guru
ah brilliant! thank you very much guys i now have a good idea of what to do!
next step, buy grinding discs, flappy discs, seam sealer, filler, metal, and primer!
bring on the staff discount!!!
pickle power!
Then there is also the way that I'm going to do it on the Lwb, I have drilled out the spot welds on existing arch mounts to remove them, then I'm going to use those as a template for the new shape of the arch higher up, then do the virtual lift as normal but without a lip sticking out and weld it from the inside, then spot weld the arch mount back on so the the original arches fit perfectly, should look really clean done that way.
You mean your arch mounts haven't rotted away?
Sounds likes like a good way if the arch lips are ok. Should look real tidy and original.
Or there is the Jay18 way with the trailer arches or the make the whole truck wider way.
The world is your oyster.
Now go forth and modify!!
- suzukisteve
- Suzuki Guru
just priced up some stuff im gonna need.
3 flappy discs
5 cutting discs
2 lots of seam sealer
1 primer
tub of p38 filler for smoothing
4x2 sheet of steel
just under 40 quid
that should do for starters I reckon!
3 flappy discs
5 cutting discs
1 primer
4x2 sheet of steel
just under 40 quid
pickle power!
You'll need more than 5 cutting discs! You want the 1.2mm ones, I just buy packs of 25/50 usually
Steve, your gonna make me jealous. Soon as i see progress it may spur me on to do my new front clip.
- suzukisteve
- Suzuki Guru
its ok they are just to bulk up the existing stock
c'mon jordi! front clip before Wiltshire
pickle power!
i'll try. I have this weekend to do everything Steve. Quick handbrake adjustment, quick sill chop, possible front clip mod and fit.suzukisteve wrote:its ok they are just to bulk up the existing stock
Plus various parts to sort shipping quotes on and remove off the LWB
Oh, hopefully get the FWH fitted.
