Fitting YJ springs to a Samurai
Re: Fitting YJ springs to a Samurai
Post by ScottieJ » Sat Mar 15, 2014 5:08 pm
Looks good!!
Now everything has settled check your Driveline angles, it only takes a few degrees to cause vibes.
Ladaman
Post by Ladaman » Sat Mar 15, 2014 5:27 pm
Thanks guys.
Good news. The vibration was coming from the front prop. I re fitted the standard Samurai one, just to give 4WD. Knowing it was too short really. That's what the problem turned out to be, not enough spline engagement so allowing wobble between the two halves.
Had a drive without it fitted and all is good. Just need to be patient now and get the LJ70 prop back from the fabricators and try that.
8-)
Post by dan_2k_uk » Sat Mar 15, 2014 6:42 pm
Great stuff. Looks like it performs well.
zukenstein
Post by zukenstein » Sun Mar 16, 2014 11:56 am
Ladaman - Looks good any pics of the back springs and how far they stick out at the back, shackle angle etc?
Zuk·en·stein - A monster made from parts of cadavers and brought to life by the power of an electrical charge.
What the fool cannot understand he laughs at, thinking that by his laughter he shows superiority instead of latent idiocy.
Ladaman
Post by Ladaman » Sun Mar 16, 2014 7:58 pm
I will get you some pics Monday night. I've been out today.
Post by Anton » Sun Mar 16, 2014 9:03 pm
Looks brilliant!
Ladaman
Post by Ladaman » Mon Mar 17, 2014 9:41 pm
zukenstein wrote:Ladaman - Looks good any pics of the back springs and how far they stick out at the back, shackle angle etc?
Here you go. Not the best shot, and I must admit I'm not overjoyed with the extra length on the tail end of the springs, but hey ho. It's all part of the "development" isn't it?
The upside is, I have just tried my 31's on, and expecting to need to do a virtual lift, but I think I'm going to be OK with just some thinnish front wheel spacers :armsup:
Who know's if it really bugs me I might just bite the bullet and get some proper YJ's.
zukenstein
Post by zukenstein » Tue Mar 18, 2014 11:40 am
cheers Ladaman thanks for that :)
Ladaman
Post by Ladaman » Fri Apr 11, 2014 7:48 pm
I went to work in the Suzuki today as the weather was nice. at lunchtime I got one of the guys to assist with a bit of a flex test. All looks to be okay, so lets see how it performs at Tong on Sunday.
Will the "protruding" shackles be an issue? Lets wait and see.
Cyprus Geoff
Post by Cyprus Geoff » Tue Apr 29, 2014 5:36 pm
Looks great, how close to the filler did you get with the new plastic wheel arch
on the drivers side?
