wings
wings
my RH wing is rusted to buggary, and I found a company that sells replica's. they tell me it has provisions for a flare, but no flare included. my question is, is there any difference between a blank front clip, and one with flares, as mine has no flares, and I'm looking at just replacing one side only
Re: wings
The bracket for a flare is a metal lip spot welded just below the pressed dimple in the wing.
If you look in the bodywork section at the Virtual Lift guide you will see them on some of the photos there.
Re: wings
Only differences there might be that it has a hole for the later side repeaters and the panel for the headlight might be different of it's for a samurai... Either way it's not that hard to sort out.
And as dan says the flare mounts are just spot welded on, remove them and the inner and outer wings are identical.
Re: wings
sweet as guys. he's going to send me some more pics, first pic I got looked pretty good, he's just going to send me some detail pics of the flare mount. also looks like the side repeater is in the right place
