revs racing
oldskoolsboy
revs racing
Post by oldskoolsboy » Thu Oct 30, 2014 5:59 pm
Hi guys just swapped engines on my sj knackered g13B to an ok g13A everything runs as it should,
except when i switch headlights on revs race upto 3000 rpm. any ideas? cheers mike
Re: revs racing
Post by ScottieJ » Thu Oct 30, 2014 7:25 pm
Sounds like the idle up system needs adjusting.
Re: revs racing
Post by Darrell » Thu Oct 30, 2014 7:38 pm
Welcome to the club :thumbup:
Needs adjusting.....................or just unplug the bugger.
Idle up SJ 413.jpg (256.4 KiB) Viewed 8217 times
oldskoolsboy
Re: revs racing
Post by oldskoolsboy » Thu Oct 30, 2014 8:35 pm
cheers guys "removed the bugger" spot on everthing works. MOT tommrow fingers crissed sorry
dyslexia stops me posting as much as i like, ages rihgting post again thankyou
oldskoolsboy
Re: revs racing
Post by oldskoolsboy » Fri Oct 31, 2014 7:16 pm
MOT failed offside front axle swivel joint has excessive play, can this be adjusted or will it need replacing?
Ladaman
Re: revs racing
Post by Ladaman » Fri Oct 31, 2014 8:16 pm
I'd think it's either knackered kingpin bearings or it needs some shims removing.
Probably the bearings need changing though.
Re: revs racing
Post by donkeychomp » Fri Oct 31, 2014 10:12 pm
Change it for peace of mind.
oldskoolsboy
Re: revs racing
Post by oldskoolsboy » Sat Nov 01, 2014 1:37 pm
any idea where i can buy a new bearing?
courior
Re: revs racing
Post by courior » Sat Nov 01, 2014 1:39 pm
Hi OldSkool .... If you want me to get you them from my local parts man send me a PM and ill try and sort you out :)
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Boyes
Re: revs racing
Post by Boyes » Sat Nov 01, 2014 3:40 pm
Kingpin bearings can be bought on eBay or most bearing suppliers, if you search on here in the axles sub forum Scott has a sticky on axles, and it lists all the bearings/dimensions etc. Just remember there's two fitted one top & one bottom on EACH side so four kingpin bearings for the front axle.
Just had a look in garage, they are 30302 J2, if you google it you will find them all over.
