emissions
emissions
i am having problems with the c0 emissions on my vitara jx 1.6 1999, I have changed the lambda sensor, plugs , distributor cap, water temp sensor,ht leads, and now the cat, plus had it terra cleaned but it still wont pass a mot so not sure what to try now the engine is running sweet no miss fire and very smooth hope someone has a few ideas
Regards
Mark
Regards
Mark
Re: emissions
1999 - is that a single point injection 8v?
What CO reading is the MOT station getting?
Re: emissions
yes single point 8v the reading was 0.5 to 0.6
Re: emissions
I know very little about SPI setups, hopefully someone will come along soon who can give you more of an idea what to do.
Re: emissions
Could try a new air filter.
Either that or it could be an issue with the injector maybe??
- Ladaman
- Suzuki Guru
Re: emissions
What about the valves or valve guides. If they aren't seating correctly or the guides are worn it could allow oil past them. Is it burning oil at all?
Is terra clean a form of injector cleaner? If not try some injection cleaner through it.
Re: emissions
Check the ignition timing with a strobe light, you need to fix the ignition to base timing first using a jumper in the diagnostic socket. Did you check the plug gaps before installing them? they should be around 28thou
Re: emissions
It's done 106000 so it burns a little oil but no smoke the engine runs very well
Re: emissions
High CO is usually a rich mixture, is it failing at idle or fast idle or both? What idle speed are you getting? You've changed the O2 which is a good start, have you thoroughly checked for exhaust leaks prior to the cat?
- donkeychomp
Re: emissions
Just before you drive into the MOT station ram a sock up the tailpipe.
Might work...
Might work...
