Hi Parts needed - 1991 Suzuki SJ 413
sjman413
Post by sjman413 » Mon Dec 29, 2014 8:21 pm
Hi guys I need some part for my Suzuki Sj 1991 413.
The part i need is a Starter motor.
the closest to Birmingham or Worcestershire area the better, and i am willing to pay up to £25 for one working. thanks guys Chris :suzuki:
Online
Re: Hi Parts needed - 1991 Suzuki SJ 413
Post by Anton » Mon Dec 29, 2014 11:14 pm
What's wrong with your current one? They're pretty easy to strip down and clean, and that usually sorts out any problems. Also, sometimes the problem is with the wiring getting old/tired and not being able to handle the current the starter needs, in which case you'll need to do the "clicky starter fix" and fit a relay.
sjman413
Post by sjman413 » Tue Dec 30, 2014 11:43 am
It sometimes will turn the engine sometimes it will just constantly click until you bang it...
Is there a guide on how to strip them? thanks Chris
Online
Post by Anton » Tue Dec 30, 2014 11:34 pm
I did one recently, they're *really* easy to do.
Just undo a few bolts and screws, clean the crud out, put it back together in reverse order and away you go.
Take pics of how it comes apart if you're unsure.
A couple of pics of me doing it.
Here's an instructibles guide on stripping a starter motor. It's not exactly the same as an SJ starter, but close enough.
Post by twiss » Wed Dec 31, 2014 10:50 am
I think I should just add that if you wanted a replacement you may be hard pushed for £25... most people seem to want at least that amount nowadays!
I'm with the strip down and clean idea though... unless the magnets have broken off the inside of the casing or the solenoid wiring is actually screwed then theres a good chance it will work properly again!
Post by turbo-tom » Wed Dec 31, 2014 4:06 pm
Strip down for me aswell doubt you will get a skinny for 25 though!!
