jagosdad
Post
by jagosdad » Wed Feb 18, 2015 3:48 pm
Hi Folks
I am putting a Pug DT and LDV box into my SJ. I have things in position but I am not sure what to do with the LDV cross member. Where ever it goes it seems to be in the way of the steering and suspension. I have fabricated plates to bolt it (the cut down cross member ) between the SJ chassis rails. I was just about to take the grinder to it and cut it into two small and less stable engine mounts but I thought I would get some advice first.
Any ideas?
- SJ2.jpg (500.05 KiB) Viewed 10032 times
jagosdad on Wed Feb 18, 2015 4:39 pm, edited 3 times in total.
- The Boss
Post
by ScottieJ » Wed Feb 18, 2015 4:16 pm
I can't visualise what you mean?
Can you post some pictures. Most people just fabricate engine mounts from scratch rather than fit a crossmember?
d_r_1989
- Winching along now
Post
by d_r_1989 » Wed Feb 18, 2015 8:47 pm
Mine is on custom mounts. Easier job than fitting cross member
- The Boss
Post
by ScottieJ » Wed Feb 18, 2015 9:43 pm
I would loose the crossmember and make custom mounts as said.
Post
by Anton » Wed Feb 18, 2015 10:24 pm
d_r_1989 - got photos of your mounts? Might help if he's got something to draw inspiration from.
d_r_1989
Post
by d_r_1989 » Thu Feb 19, 2015 6:57 am
Ill try get to unit tonight and get some
Boyes
Post
by Boyes » Thu Feb 19, 2015 7:30 am
Again we fabricated custom mounts, although the engine I sourced didn't come with a cross member another thing to bare in mind is the height of the engine as it will be close to the sump if you are still spring under axle.
I would post pictures but don't have any of the mounts on my phone, they're not the prettiest of things either.
jagosdad
Post
by jagosdad » Thu Feb 19, 2015 2:17 pm
Thanks to everyone who posted a reply. I am going to chop up the cross member and create something ugly. I would appreciate and pics of the custom mounts or any ideas about how haw forward the engine should sit.
S
jagosdad
Post
by jagosdad » Thu Feb 19, 2015 5:20 pm
I know this shows my novice credentials but,......can I stick my axle under the spring? Would this be a useful mod?
The sj is not going on the road.
Post
by ROBBIE » Thu Feb 19, 2015 6:45 pm
jagosdad wrote:I know this shows my novice credentials but,......can I stick my axle under the spring? Would this be a useful mod?
Yep its called spring over axle, soa. In my opinion a nasty modification
