Where best to get universal joint?
ferris
Post by ferris » Fri Sep 18, 2009 5:51 pm
Does any one know a good place to get universal joints from?
One of mine appears to be knackered, and is causing a annoying juddering.
dan
Re: Where best to get universal joint?
Post by dan » Fri Sep 18, 2009 8:20 pm
any motor factors just give them your reg and they should be able to match it up
Post by ScottieJ » Sat Sep 19, 2009 10:44 am
or look up a bearing supplier,thats probably you're cheapest bet!
ferris
Post by ferris » Sat Sep 19, 2009 5:32 pm
Ok cool. So its not a specific suzuki part then.
Henry
Post by Henry » Sun Sep 20, 2009 9:27 pm
No, not at all.
Suzukis will be about £10 dearer.
Ginger_boy
Post by Ginger_boy » Mon Sep 21, 2009 7:30 pm
Yep Bearing suppliers best place although to identify them you may have to do some acurate measuring of dimensions.
If your interested I may have a spare one that I could send.
The same UJ element fits some very old shaft driven pumps where I work, and we keep several spare elements
Henry
Post by Henry » Mon Sep 21, 2009 8:32 pm
I have joints hear for a 410. They have nipples in them also.
The wont fit sammys as the caps are bigger.
ferris
Post by ferris » Fri Sep 25, 2009 4:45 pm
Cheers for the advise guys. Iv managed to track one down, should be getting it tomorrow if all go's to plan.
ferris
Post by ferris » Thu Oct 01, 2009 9:53 pm
Got round to changing the uj earlier. What a bloody nightmare!!! :evil: Ended up having to angle grind the old one off, then all the pins fell out of the new one :angry:
All done now though, although there is still a bit of a judder, so there might be another one on its way out. Should be easier the second time round.........i hope :lol:
Post by ScottieJ » Wed Apr 28, 2010 1:14 pm
does anyone remember the dimensions of the UJs in the later sj props (not the skinny ones) as i need go buy some and i cant remember the dimensions.
Scott
