Beddy Rascal
stevepsj413
Beddy Rascal
Post by stevepsj413 » Thu Jul 07, 2016 5:33 pm
Managed to get this picked up the other day, it had already been stripped (badly) so it only took 3 of us to lift it onto the trailer, all the parts went in the back of the tipper we were towing with and off she went to her new home.
When I say its been stripped, I mean stripped. Not only had he taken rear axle off and stripped it fully down apart from the diff, the engine was sat stripped, no cam belt on it, belt pulleys been hammered off and is now square, rocker cover removed and rest of engine sat exposed, full of twigs. All the front suspension was totally taken apart. Last thing he gave me to put on tipper was 3 paint tubs full of rusty nuts bolts and washers, "thats all the bolts ive taken off everything, there all there, somewhere!"
What a bloody maverick!!
Started to put bits back together so I can see whats there and whats missing. Took me 2 days to find all the bits to put rear axle and drums back together, the big bits were easy to find but the pins that hold the shoes in were hiding. Got some rear wheel bearings and an engine stand for my birthday so the rear axles back together and on, and the engines on the stand.
Enough words, now some photos.
Started re building front suspension
This needs sorting properly.
Rot above drivers door
Bit of rust around the screen
One of the tins of bolts etc
Engine on the stand
Engine on the stand
Bin full of engine parts
Suzuki cap from suspension strut
Suzuki calipers
Suzuki calipers
Suzuki rocker cover
Suzuki rocker cover
Re: Beddy Rascal
Post by Jordi » Thu Jul 07, 2016 6:23 pm
Plans?
stevepsj413
Re: Beddy Rascal
Post by stevepsj413 » Thu Jul 07, 2016 7:48 pm
Jordi wrote:Plans?
Nothing special, just going to get it back on the road and see where it goes from there. I like having something to get stuck into and it'll keep me out of trouble for a while. As bad as it looks its 100% better than the 2nd kja I've got.
I do know im going to paint it red though, think thats the best colour for these.
They are quite odd little things tho, the engine sits at a 45 degree angle and the bottoms of the seats are covered with heat resistant insulation because your sat right on top of the engine, the brake servo and cylinders mounted directly on the back of the pedal box. And ive never had a car that didn't have a bonnet!
Re: Beddy Rascal
Post by dan_2k_uk » Sun Jul 10, 2016 11:11 am
Looks like it needs a little love. I've always fancied one for a laugh. I quite like them in that light faded blue.
Re: Beddy Rascal
Post by Anton » Sun Jul 17, 2016 2:15 pm
As promised...
:poke:
stevepsj413
Re: Beddy Rascal
Post by stevepsj413 » Sun Jul 17, 2016 8:42 pm
Done a bit to this over the weekend, lots of welding needed. To be honest I wish the previous owner hadnt started, his work is shocking to say the least, it all needs cutting out and re-doing. So I made a start.
Ground down, dont look too bad.
The bit at the tops his patch, hit with hammer it fell off. Cut back to good metal and done better.
Re: Beddy Rascal
Post by Anton » Mon Jul 18, 2016 1:55 pm
:thumbup:
Re: Beddy Rascal
Post by Jordi » Mon Jul 18, 2016 5:51 pm
Plenty to be getting on with.
Real pain in the back side when you have to sort someone elses bodge out.
