gear box
Re: gear box
I havn't reli got a clue, but sounds like it may be your selector, have had a couple o cars that jump out o gear due to the selector. Also has it got the right level of oil?
Dan
Dan
Re: gear box
alot of old minis do this. Im really lucky to have one that dosent. Ive heard people say its the synchro mesh but i havnt go a clue about gearboxes.
- urbanzook
- Winching along now
Re: gear box
oils good the rest i ant got a clue
Re: gear box
It's your selector. If I remeber correctly there is a poly bush on the gear lever that is now worn and needs replacing.
- urbanzook
Re: gear box
have you dun one befor is it easy / hard as my haynes manual dont cover the box in depth how much is the part
many thanks zp
many thanks zp
Re: gear box
Never done one myself, but I do have a workshop manual. Let me see if I can find more info on how to do it. Will try and get it posted as soon as I can.
- urbanzook
Re: gear box
life saver :nurse:
Re: gear box
I have a gear box out of my 413 dont know that much bout them yet, all I no it is the original one for a 1995 413 If you want it and can arrange pick up its yours. I live outside glasgow!
Girvy
Girvy
- urbanzook
Re: gear box
many thanks for the offer Girvy but i have one out off my other anus on an running now but i wanna fix the other one as a back up i try to have 2 off every think for this reson f**k it swap it fix it so my anus is down for less time as pos as its my work car. dont wanna use my othere on a bilding site. is 2 low.
