Diff breather
Diff breather
Post by ROBBIE » Sat Apr 01, 2017 10:06 pm
What would happen if they get blocked? Is it the end of the world as we know it?
Re: Diff breather
Post by Darrell » Sat Apr 01, 2017 10:12 pm
Yes, the seals would explode and send stinky oil everywhere.
or maybe not ;)
Re: Diff breather
Post by twiss » Mon Apr 03, 2017 8:05 am
I had issues with blocked breathers before... put new oil seals in and a week later it would chuck all the diff oil out past the seals!
As a good side effect though makes it more difficult to suck water in the breather :P
Re: Diff breather
Post by ROBBIE » Mon Apr 03, 2017 10:29 am
So it will cause problems, only reason I ask is because, on the axle I'm building up for the LJ, the breather cap was solid, no movement at all. So plan was remove and put a breather hose in, but the hole doesn't seem to go all the way into the axle. I can't see or feel anything inside the casing, its just smoth :er: I don't have a compressor to blow through it and don't want to put me mouth anywhere near it
Re: Diff breather
Post by Anton » Mon Apr 03, 2017 1:04 pm
I've blown a set of seals because of a blocked breather. If it's a road car, it's sort-of ok to just pull the breather - but ideally you'd at least put something over it to stop things getting into your diff, but allowing air out. I ran hose from the diffs up to the engine bay.
Re: Diff breather
Post by ROBBIE » Mon Apr 03, 2017 1:17 pm
Anton wrote:I've blown a set of seals because of a blocked breather. If it's a road car, it's sort-of ok to just pull the breather - but ideally you'd at least put something over it to stop things getting into your diff, but allowing air out. I ran hose from the diffs up to the engine bay.
Yeah that was the plan run a hose into the engine bay
zook123
Re: Diff breather
Post by zook123 » Mon Apr 03, 2017 1:44 pm
Have you tried poking anything into the hole? Mine was a bit gunged up, so I removed the cap and spring, pushed the crud out, and ran a diff oil change.
I then fitted both diffs with breathers, into one breather into the engine bay, same as the gearbox/transfer box, I plan to follow the diffs into a single pipe into a future snorkel, and the same for the gearbox/transfer box.
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Re: Diff breather
Post by ScottieJ » Mon Apr 03, 2017 3:02 pm
There is no good reason to plumb breathers into a snorkel. They shouldn't really be linked together either.
If you were ever to roll (never say it won't happen) just think about where the oil might end up.
Re: Diff breather
Post by ROBBIE » Mon Apr 03, 2017 3:50 pm
ScottieJ wrote:There is no good reason to plumb breathers into a snorkel. They shouldn't really be linked together either.
In the air box mainly.
zook123
Re: Diff breather
Post by zook123 » Mon Apr 03, 2017 4:03 pm
They're linked together according to oils, ie Diffs (GL5) and Gearbox/Transfer Box (GL4)
But yeah, makes sense, if it does fall over, im gonna get oil in the intake, maybe i'll run it beside the snorkel, with a nice cap on ;)
