sj axles
ton24
sj axles
Post by ton24 » Thu Dec 30, 2010 8:04 pm
can anyone help me?.can i put a front axle diff with its housing in a rear axle?.are they both identicle........ can i just withdraw half shafts and unbolt it from the axle housing then bolt it in to my rear axle?.
Henry
Re: sj axles
Post by Henry » Thu Dec 30, 2010 8:07 pm
Short answer no you carnt.
Long answer is yes you can, but you need to strip the front diff down to change a few gears over from front to back for it to fit.
ton24
Re: sj axles
Post by ton24 » Thu Dec 30, 2010 8:12 pm
sorted.is it a big job.wots involved mate..oh and thank u ...
Henry
Re: sj axles
Post by Henry » Thu Dec 30, 2010 8:13 pm
In what? Changing a like for like diff or changing a front to back?
ton24
Re: sj axles
Post by ton24 » Thu Dec 30, 2010 8:30 pm
changing a front diff to a rear diff.do u know anybody that recons diffs.i have a pair of axles that r good(spare).but the rear diff on my sj is leaking and has a bit of play in bearings.(play in the diff bearing).
Henry
Re: sj axles
Post by Henry » Thu Dec 30, 2010 9:29 pm
The play you can feel will be in the prop flange. This is the pinion bearing.
You could just replace the crush collor to stop it from leaking, but it would depend on how bad the bearing is and what you use it for.
To use the front in the back, you need to change the side gears. This requires the stripping down of both diffs. You will need impact guns ect to get them apart, and the diff you plan to re use will need to be set up properly. This will need to be done by a garage.
Hope this helps
ton24
Re: sj axles
Post by ton24 » Fri Dec 31, 2010 12:56 am
thanks mate.yes it does help.im just gunna get it done by the pro's.thank u.do u know anybody that rebuilds diffs in the hull area.
Re: sj axles
Post by Edweird » Fri Dec 31, 2010 2:19 pm
I know a guy who might possibly be able to help with the diffs in north-east midlands, Matt Pearce. He's on the edge of Caistor, on Brigg Road, and runs a 4x4 specialist garage and also deals a few cars too. My SJ went there for a service and my Mum's 300TDI Disco is a regular visitor.
If you want to give him a ring: 01472 852266
And here's a picture of his garage from google maps:
That's the only place I can think of, and I'm pretty sure I'm one of the closest people to you on the forum, 'cause I'm just on the other side of the Humber from Hull.
ton24
Re: sj axles
Post by ton24 » Sun Jan 02, 2011 4:59 pm
thanks mate that has helped a lot will give him a ring when i get back to work on tuesday.i think i hav a good set of front seats at work out off my other sj they r high back and r gray too..will get in touch when i find them.thank u again
Re: sj axles
Post by Edweird » Mon Jan 03, 2011 11:34 am
ton24 wrote:thanks mate that has helped a lot will give him a ring when i get back to work on tuesday.i think i hav a good set of front seats at work out off my other sj they r high back and r gray too..will get in touch when i find them.thank u again
Glad I could be of some help.
As for the seats, that's fantastic. Thanks a lot dude! :mrgreen:
