Ignition Barrel
Turb()
Ignition Barrel
Post by Turb() » Sun Jan 16, 2011 4:32 pm
Rght, didnt know what section to put this in so I thought general should cover it :p
Got my new lock set off ScottieJ (much appreciated!) and fit the door lock fine with no problems, but I'm having a slight issue with the ignition barrel! I.E. I've got no idea how to change it :shock:
The new one has go 2 threaded holes all the way through the barrel, that presumably a couple of bolts go through...
But my old one doesnt have holes right the way through, and where I would assume a bolt goes it has just got a stud type thing that seems to be held tight.
Also you can only see one as the other one is on top of the steering column under the dash :argh:
Anyone got any suggestions? lol :roll:
Henry
Re: Ignition Barrel
Post by Henry » Sun Jan 16, 2011 4:35 pm
They are bolted onto the steering colom with 2x snap now bolt thinks.
They are an anti theft device, but a smal chizzel or center punch you can start them off and undo them with your fingers.
Re: Ignition Barrel
Post by Tramp » Sun Jan 16, 2011 6:56 pm
Henry wrote:They are bolted onto the steering colom with 2x snap now bolt thinks.
i got mole grips on mine, then re-used them
Turb()
Re: Ignition Barrel
Post by Turb() » Sun Jan 16, 2011 7:21 pm
Even the one on top of the steering column?
Re: Ignition Barrel
Post by ScottieJ » Sun Jan 16, 2011 7:45 pm
No worries matey :mrgreen:
Pop the clocks out of the dash and you can get to the top one easier :mrgreen:
I also use mole grips for mine.
While its out replace the studs with bolts to make life easier in the future.
Re: Ignition Barrel
Post by twiss » Sun Jan 16, 2011 11:44 pm
I found hammer and screwdriver works OK...
I happened to have them in the truck when I snapped the key in the ignition barrel :)
Turb()
Re: Ignition Barrel
Post by Turb() » Mon Jan 17, 2011 10:17 am
Sweet cheers lads!
It was only the visible one that had the anti theft thingy on it. I couldnt get mole grips on it so the hammer and chisel method worked for me!
The one the other side was just a bolt so goty a socket on it and happy days!
Cheers for all your help lads 8-)
