diff removal
Jamie_stafford
diff removal
Post by Jamie_stafford » Wed May 04, 2011 8:52 pm
hi. I think my diff is buggerd and i want to get it out and have a look as it has been whineing for ages and now it sounds like theres a rock jumping around in there, not sure how easy it is to get out, can anyone help? :er:
Suzuki, because life's to short to be fixing landrovers!
Re: diff removal
Post by Darrell » Wed May 04, 2011 9:23 pm
Have a shifty here
http://www.suzuki4x4.net/manual/sj/chapter16.pdf" onclick="window.open(this.href);return false;
Jamie_stafford
Re: diff removal
Post by Jamie_stafford » Thu May 05, 2011 10:58 am
sorry, i cant see pdf files as i only use my ps3 and fone for the internet
ferris
Re: diff removal
Post by ferris » Thu May 05, 2011 10:16 pm
Jack the back up, take off the back wheels, take the front of the drums off, undo the 4 bolts holding the drum on the axle, then you can pull the half shaft's out enough so they disengage from the diff, (you may have to disconnect the brake lines from the drums) take the prop off, drain the diff oil, undo the bolts round the diff, and then it should come out.
Thats pretty much how its done, off the top of my head.
Hope that helps ;)
Henry
Re: diff removal
Post by Henry » Thu May 05, 2011 10:38 pm
You may also need a slide hammer.
If it was me i would take the outside of the dum, brakes and back plate off. But thats me :lol:
Re: diff removal
Post by ScottieJ » Fri May 06, 2011 1:35 pm
you can sometimes manipulate the solid brakelines enough to pull the halfshafts out enough to clear the diff without dissconnecting them (remember to dissconnect the handbrake cables though if its on the drums :thumbup:)
saves a bit of time and hassle if you can :thumbup:
And yes as henry says you might need a slide hammer to get the shafts out.
I made my own
Jamie_stafford
Re: diff removal
Post by Jamie_stafford » Fri May 06, 2011 6:57 pm
thats one hefty slide hammer you got there! i will have a go at it on my next day off
Jamie_stafford
Re: diff removal
Post by Jamie_stafford » Wed May 11, 2011 9:45 pm
Its out! And well and truely buggerd! Thanks for the help
Re: diff removal
Post by ScottieJ » Wed May 11, 2011 10:22 pm
Jamie_stafford wrote:thats one hefty slide hammer you got there! i will have a go at it on my next day off
Cheers, yeah its a bit on the large side :lol: works bloody well though :lol:
It all went smoothly then eh? They usually go back together a lot easier than they come apart :thumbup:
Jamie_stafford
Re: diff removal
Post by Jamie_stafford » Sun May 15, 2011 8:53 pm
It all went back in real nice, but ive now found that it was not the cause of the nasty banging and nocking witch ive still got, possable transfer box?
