- The Boss
![The Boss The Boss](./images/ranks/rank11.png)
Post
by ScottieJ » Thu May 12, 2011 11:45 am
Parrot & I were talking about 'Halo' style cages the other week and whether or not we thought they were a good design to use for a cage.
I think if you did one like this I would trust it a lot more than the usual style without the B-hoop.
What do you think Parrot?
This is the type of 'Halo' design Cage without a B-hoop that I'm not sure I would like to trust in a bad roll over.
What are other peoples opinions on halo style cages?
Henry
- Suzuki Guru
![Suzuki Guru Suzuki Guru](./images/ranks/rank6.png)
Post
by Henry » Thu May 12, 2011 7:57 pm
They look more side impact that rolls. Im guessing that its a complete hoop above your head with legs?
parrotveasey81
- Can I have a tow
![Can I have a tow Can I have a tow](./images/ranks/rank3.png)
Post
by parrotveasey81 » Wed May 18, 2011 8:06 pm
yea the top one is how i would like mine,the other one is ok but for me i would want brace's on the top of the uprights and they both could do with cross basrs to help take the load of a big roll
rockwatt
- Recommended Trader
![Recommended Trader Recommended Trader](./images/ranks/rank12.png)
Post
by rockwatt » Thu May 19, 2011 11:31 am
much better and stronger like this.
To get the same strength from a halo you would need a double triangulated B pillers.
IMO of course
![Image](http://i166.photobucket.com/albums/u116/muddy_dunk/duncan030.jpg)
Rocklobster gears , refurb cases , dual cases , su manifolds , jimny rocklobster conversions inc speedo drive, t/case heavy duty mounting arms and rock buckets, bespoke fabrications and machining,
Contact me for details.
parrotveasey81
- Can I have a tow
Post
by parrotveasey81 » Thu May 19, 2011 8:36 pm
rockwatt wrote:much better and stronger like this.
IMO of course
i take it when you say double triangulated B pillers you mean the cross in the b pillers
![scratch :er:](./images/smilies/icon_scratch.png)
like what i said above
rockwatt
Post
by rockwatt » Thu May 19, 2011 11:43 pm
Sorry i meant A pillers.
You realy do need a full b hoop with at least one diagnal and if you go for a halo on the front half the it should realy have double A pillers ie a normal raked + one upright as the time a front halo will fail is doing a front endo. You should also have atleast one diag in the roof section. A cental strait roof bar does nothing.
parrotveasey81
- Can I have a tow
Post
by parrotveasey81 » Fri May 20, 2011 9:18 am
any chance you can do a pic of what you mean,im haveing a blonde moment
![Embarrassed :oops:](./images/smilies/icon_redface.gif)
rockwatt
Post
by rockwatt » Fri May 20, 2011 1:32 pm
Double a pillers like this woyld be needed to get the same strength as a A hoop or one piece side rails.
If you look at the pic i posted above with carfull placing of the front cross bar then you can get the look of a halo with the strength of one piece side rails or A hoop.
![Image](http://i129.photobucket.com/albums/p203/rwatt47/bc579936.jpg)
parrotveasey81
- Can I have a tow
Post
by parrotveasey81 » Fri May 20, 2011 9:59 pm
![Cool 8-)](./images/smilies/icon_cool.gif)
i was thinking it was how you said it was 2 a pillers each side.
now do i go for a piller lift-right or front-back
the thing is i want mine to hug the body as best as pos so what do you reckon is the best option
rockwatt
Post
by rockwatt » Sat May 21, 2011 10:53 pm
parot the one in the pic i posted above fits about as close as you will get
![Image](http://i166.photobucket.com/albums/u116/muddy_dunk/markanddunc069800x600.jpg)
