How do I get rid of the glue under carpets
Cyprus Geoff
Post by Cyprus Geoff » Wed Feb 08, 2012 10:19 am
Ripped my manky carpets out last night to see what they were hiding.. Mostly GLUE but what a mess that glue is!!
Can any one offer ideas on how to get rid of it please?
Cheers,
Geoff
chrisj410
Re: How do I get rid of the glue under carpets
Post by chrisj410 » Wed Feb 08, 2012 12:09 pm
I use lighter fluid at work mate
Post by ScottieJ » Wed Feb 08, 2012 12:20 pm
A controlled fire maybe :smokin: :lol:
Do you want to remove the black tar like layer as well? I've heard that if you fill the footwells with ice and get them really cold it goes brittle and you can chip it off, not tried that myself though?
chrisj410
Post by chrisj410 » Wed Feb 08, 2012 12:31 pm
It evaporates quickly we rub/wash it down after, just in case,but you'd literally have to be smoking while doing it for it to go up, well I've not had a problem n I work with static plexi and plastics
Post by twiss » Wed Feb 08, 2012 4:20 pm
I used a grinder to get rid on the tar stuff... worked quite well in the end haha
Cyprus Geoff
Post by Cyprus Geoff » Wed Feb 08, 2012 5:15 pm
Thanks for your replies peeps.
Tried Petrol - not great.
Now using White spirit and wire wool - very arm achey slow but getting there.
Eats me rubber gloves though :shock: :shock:
Post by ScottieJ » Wed Feb 08, 2012 5:17 pm
what about a wire brush attachment on a hand drill? that would speed it up and save your elbows.
Post by dan_2k_uk » Wed Feb 08, 2012 11:02 pm
Some of mine had gone dry and cracked which I chipped off easily with a chisel.
The rest was quickly buzzed off with a 100mm wire wheel in the grinder.
Dan
Cyprus Geoff
Post by Cyprus Geoff » Sat Feb 25, 2012 9:30 pm
Have learned to let the glue go yellow in the air for 48 hrs then wire brush in drill whisks it away. Where I used white spirit it remains a gooey mess - be warned!
Post by mike harris » Mon Feb 27, 2012 10:10 pm
two pack thinners works
mike
