Fuel tank replacement
Rjmaas512
Post by Rjmaas512 » Mon Feb 20, 2012 9:48 am
Hello,
I have a LWB Spanish SJ413. I have what i believe is jap tank.
I was wondering how easy it is to replace the sender and then fit the tank.
I am stuck at uni so don't have any jacks or anything with me so would it be as simple as drop the tank and bolt the new one on, or do I need to jack the chassis away from the rear axle to give enough room to replace the tank.
And if the sender is different is there a way to get it to work somehow......?
Thanks,
Rob
Re: Fuel tank replacement
Post by ScottieJ » Mon Feb 20, 2012 11:30 am
should be able to do it on the floor without a Jack, I always have done but it can be awkward, an extra set of hands always helps.
Problem is Spanish senders don't fit Jap tanks.
Rjmaas512
Post by Rjmaas512 » Mon Feb 20, 2012 4:06 pm
Ah bugger, will try and get a Spanish tank then...
Anyone have one?
