Timing
Gardiner
Timing
Post by Gardiner » Thu Dec 20, 2012 6:48 am
What is the timing process/settings for 1600 8v with a SU carb I have a timing light coming at the weekend so might get it sorted (Cross Fingers).
Thanks In Advance
Re: Timing
Post by dan_2k_uk » Thu Dec 20, 2012 8:03 am
Make sure the vac advance is located on the air filter side of the butterfly and set it 10 deg before tdc at tickover.
Re: Timing
Post by ScottieJ » Thu Dec 20, 2012 10:45 am
Or just dissconnect and blank off the vac advance while you set the timing, that's what I usually do.
