Pics And Help With Putting Sami Axles On A 410
Famerbennie
Post by Famerbennie » Tue Mar 26, 2013 6:13 pm
Can Anyone Help Or Has Any Pics Of Sami Axles On A 410/413
Re: Pics And Help With Putting Sami Axles On A 410
Post by Jordi » Tue Mar 26, 2013 6:39 pm
All i know is the saddles need moving in 40mm http://forum.suzukiclubuk.co.uk/vi ... 12/t,2801/
Post by ScottieJ » Tue Mar 26, 2013 7:17 pm
Here's a guide but you need to put this link into google translate
http://pirate4x4.no/forum/showthread.ph ... uraiaksler
Some of the measurements are wrong though, use the measurements from the thread Jordi linked as those are 100% correct.
basically it's easy, you just need to make sure that the perches stay at exactly the same angle as they were originally to keep the caster and prop UJ angles correct.
The diff side perch, needs modifying so because it ends up partially on the diff housing, so make sure you take your time to get this as flat as possible
This is mine but my axle is far from standard.
