Carb help
Carb help
Right folks I'm fairly new to all this sort of thing but iv just bought myself a sj 413 samurai it's a jx if that makes a difference it's had a fair few mods to it n I love it but it seems to have very little power the engine runs fine but I struggle to get much above forty mph and iv never got it into fifth gear lol it's fitted with 31" tyres and its got spoa I don't think I really want to go much faster than forty tbh as it feels like I'm I a boat but I just feel like I have to thrash it to get it to move years ago I had a webber carb on one and it made a hell of a difference to power I was wondering what model webber I would need or what other carb I could fit I know about the su's but they seem hard to get hold of I will eventually when funds allow swap to a Vit engine but at the minute I'm after a cheapish fix is there any i could source fairly easily from a scrappy im only doing green laning so not to worried about the extreme angles cutting the engine thanks also the steering is sloppy I can turn the wheel a quarter of a turn before anything happens is this normal ?????
Re: Carb help
You could try this nikki, I think it's the correct size to fit on the suzuki, know a few people that use them and they are basically a copy of a weber
http://www.ebay.co.uk/itm/Chevette-nikk ... 19e6972b5f
Click Here for Ebay Listing
Re: Carb help
Daihatsu charade, subaru justy and hyundai pony were all straight swaps. They are rare to find in scrappys now though.
Re: Carb help
twiss wrote:You could try this nikki, I think it's the correct size to fit on the suzuki, know a few people that use them and they are basically a copy of a weber
Like any carb it will need to be correctly jetted.
Re: Carb help
Ok will that nikki be ok then and how do I jet it up
Re: Carb help
You may find this useful for your steering problem..
http://forum.suzukiclubuk.co.uk/vi ... =15&t=3310
Re: Carb help
Cheers buddy
Re: Carb help
Also I read on a post somewhere that if I had free wheeling hubs I could weld the front diff up is this true lol
Re: Carb help
I wouldn't advise it.Nibzzy01 wrote:Also I read on a post somewhere that if I had free wheeling hubs I could weld the front diff up is this true lol
- Edweird
Re: Carb help
I suppose the theory is correct.Nibzzy01 wrote:Also I read on a post somewhere that if I had free wheeling hubs I could weld the front diff up is this true lol
You can't use 4WD on the road because there's no centre diff and people use free wheeling hubs to disengage the hubs from the rotating parts of the axle to reduce rolling resistance and wear, but as the front diff is only really used off-road you could weld it up.
However, I think the gains from locking a front axle won't be nearly as much help as locking the rear, because when you accelerate, the nose gets lifted so on slippery surfaces you could easily spin both front wheels together, diff or no diff. That's based on what I saw and experienced at Wagtail.
Personally, based purely on the theory of how they work, I think a Powertrax Lockright Diff Lockers are pretty damn good. Basically, they allow one wheel to turn faster than the 'diff' and that's it, so in a straight line, or if your wheels start to spin a little bit, you've got a locked axle, but on the road when you're driving to or from an off-road site the outside wheel will overrun in corners.
