Passenger alignment
- Cyprus Geoff
- Can I have a tow
Passenger alignment
The Mrs is complaing of a draft around her hip. Does anyone know how I can adjust the door to leave the window frame etc where it is and twist the lower half so it seals properly.
Old pic below but it show the problem.
- IMG_3439.JPG (1.63 MiB) Viewed 6137 times
Re: Passenger alignment
complaining of a draft in cyprus? its a hard life
Sorry to not be helpful but most of my bodywork repairs involve a club hammer. or in this case a jumper and a coat
You should be able to adjust the door catch slightly and that should pull the bottom of the door in tight when you close it.
If that doesn't work a bit of brute force and ignorance can twist an SJ door back into shape quite easily
- muddymesser
get her a blanket
Could always just take the roof off, she won't notice the breeze through the door then
- Cyprus Geoff
- Can I have a tow
Useless P*** taking buggers! What sorta bloody forum is this?
I just told her she had to walk
(not that brave TBH)
Tried adjusting the centre just need to find a safe way to apply enough force BFH would be fun but not to glamourous a fix!
I'll just wait and see if someone sensible has any advise
Is is definitely the door that's bent? Does the bottom need pushing in or the top pulling out?
Park it next to a wall and using a porta-power / bottle jack and some blocks of timber push it back in shape.
- Cyprus Geoff
- Can I have a tow
Good idea, will give it a go, and tje bottom needs pushing inwards
- Ladaman
- Suzuki Guru
You could let her drive!
