Planning a turbo 1.6 Vitara Tin Top
RickUK
Re: Planning a turbo 1.6 Jimny
Post by RickUK » Wed May 27, 2015 7:21 am
Alot more work involved than what you think,when you take into account all the work involved i personally dont think you will gain much,not sure how you would stand on the insurance side of things either.
Hope it does work out for you of course but the 'rewards to effort' involved in my mind dont stack up,just my personal opinion of course.
Deceased.
Current wheels.
trapper
Post by trapper » Wed May 27, 2015 12:20 pm
I do know what you mean. However, I do like a challenge mainly to find the solution. Research has given me a layout and yes, it could be fitting a 2 litre or whatever would achieve the same result and a lot easier my thoughts are to show a junior someone (family) the value of engineering/how its made, whilst we attempt it, as opposed to go buy it press a button mentality that is so prominent these days. Also I need a bespoke vehicle for my work.
Post by Anton » Wed May 27, 2015 2:20 pm
Instead of turbocharging the 1.6, have you thought about an engine swap to something with more power/torque right out of the box? A J20 2.0 litre might be a good swap. Might be...
I'm not sure which option would be more work, but the engine swap would probably be more insurance friendly. Probably...
Post by twiss » Wed May 27, 2015 6:09 pm
Have you thought about a supercharger instead of a turbocharger?
I reckon its less work than using a turbo.... because its mostly just the bracket fabrication and a pulley/belt combo
Will probably work out easier than adapting the exhaust for turbo
trapper
Post by trapper » Wed May 27, 2015 7:27 pm
Exhaust ah that must be the bit I'm missing on the Vit lol. A supercharger would be good if I had one ....... no lag under acceleration and also less heat problem and less problems with balancing any catalyser. I do take on board the 2.0 litre engine argument but again I don't have one.
For now I'm adopting the old skool idea of make it handle and stop before the go factor is modified..... I do like cutting myself shaving every morning as opposed to trimming roots of daisies
Post by twiss » Wed May 27, 2015 7:35 pm
well the title is "turbo 1.6 Jimny" :P
On the subject of handling and stopping... do some rear discs :)
Post by donkeychomp » Wed May 27, 2015 8:09 pm
Rear discs probably won't change any stopping power but they are much easier to maintain.
Post by twiss » Wed May 27, 2015 8:12 pm
To be honest on my spanish sammy as soon as the drums start to go a bit wonky (after every pay and play!) you end up losing most of the brakes even if there's no leaks!
I would imagine that Jimnys have improved brakes though
trapper
Post by trapper » Thu May 28, 2015 6:10 am
Twiss your right so how do I change the title? I'm ok with a welder hacksaw or file give me a pc or laptop and I'm lost
Post by twiss » Sat May 30, 2015 6:09 am
Click the edit button on the first post :)
