Mikes lwb build and repairs !
- mike harris
- SCUK is my life
Re: Mikes kja hybrid challenge truck updated 27/08/2015
Yeh there cool, to valuable for off-roading.
I'm going to do away with my lockers and fit spools front and rear I've decided.
Aim for this truck is relierbilaty, cutting out weak links is what I'm trying to do
- robbie1985
its crazy to think the yanks made something like 700,000 of them. did mr rover have one at his beach house after the war and used it as the base for the series 1 landy?
it makes sense to if your only gonna use it offroad. how do the spools work? i've heard about them but never come across them
Spools lock the left driveshaft to the right one permanantly, so you don't have a "differential" anymore. Left and right have to turn equally, no matter what.
Utterly terrible for road use, probably even illegal, but utterly superb for drift cars and offroad only vehicles.
- mike harris
- SCUK is my life
I want to find a complete spool not a mini spool.
Don't want standard carier I want to upgrade the whole lot.
Want to find one you literally bolt the crown wheel too
Mike
Mike
- ektoz
i was looking also for that kind of spool, could not find one
http://offroadwarehouse.com/i-10167973- ... inder.html
thats what the rock bouncers use
I've never seen one made for a suzuki diff.
- mike harris
- SCUK is my life
I might get two made
mike harris wrote:I might get two made
You want someone to make you one of these?
I should imagine it wouldn't be difficult if you had the skills and tools - just take a pair of side gears, grind them down and weld them onto a shaft of the right size, then some kind of plate to attach it to the ring gear (vice-versa really, but you know what I mean).
I'm sure Richard could do it, it's just - does the man have the time?
And is all of that going to be worthwhile vs a mini spool?
- mike harris
- SCUK is my life
Anything welded wouldn't be strong enough
Would need to be machined
Il see what's what il low my lockers up then worry about it
- mike harris
- SCUK is my life
Bits bolted on
Engines in
Gearbox in
Tbox in
Shocks on
Dash bar and pedals in
Engines in
Gearbox in
Tbox in
Shocks on
- image.jpg (572.57 KiB) Viewed 7711 times
