Kawazonkey
Re: Kawazonkey
Post by donkeychomp » Fri Dec 11, 2015 12:40 am
Wow an LJ hard top panel. Paint it and hang it back up!
Re: Kawazonkey
Post by ScottieJ » Fri Dec 11, 2015 1:00 am
donkeychomp wrote:Wow an LJ hard top panel. Paint it and hang it back up!
i can't do that, it will ruin it's patina. unless it gets fitted to an Lj. It's survived 30+ years in its primer so I'm sure it can survive another 30+ :smokin:
Martin86
Re: Kawazonkey
Post by Martin86 » Fri Dec 11, 2015 8:28 am
Re: Kawazonkey
Post by donkeychomp » Fri Dec 11, 2015 8:01 pm
The race bike is pretty much done now. Finished the tank today and had a nerve wracking time putting the decals on. They have to be spot on first time.
Re: Kawazonkey
Post by donkeychomp » Fri Jan 01, 2016 11:10 pm
All finished. Put her on the Yamaha forum for sale and I was amazed at the lack of interest. So she's on ebay.
Re: Kawazonkey
Post by donkeychomp » Fri Feb 05, 2016 9:29 pm
NEW PROJECT!
Another RD250. Got the frame today, I already have some other parts, wheels, tyres, forks etc. An engine would be nice.
Wonder if a Vit lump would go in?
Re: Kawazonkey
Post by Anton » Sat Feb 06, 2016 7:29 pm
donkeychomp wrote:Wonder if a Vit lump would go in?
Anything is possible except skiing through revolving doors. :popcorn:
Re: Kawazonkey
Post by donkeychomp » Sat Feb 13, 2016 10:01 pm
Frame forks and yokes all done and ready to go on. The roller bearings I bought don't fit so I used good old 1/4" ball bearings instead. Nailed it all together and the bloody forks don't fit. Shazbot. Found some YPVS yokes on ebay (the forks will fit those) so the are on the way and the roller bearings can be used on them. I need to strip and rebuild the Marzocchi shocks I have and plonk the wheels on then I'll have a rolling chassis.
And bidding on another project bike as we speak. Fingers xxd.
Re: Kawazonkey
Post by donkeychomp » Sat Feb 20, 2016 10:35 pm
Been a busy few days. YPVS yokes arrived and did the bars. Both excellent but needed the usual refurb. Then the headlight and brackets arrived (new!) and the front end is all back together. Ordered an LC swing arm, going to make this into a monoshock frame instead of twin shocks. It's been done before and it's worth it. Reduces weight and improves handling too. Yes it inloves a bit of welding and realignment of bits but it'll be worth it!
Re: Kawazonkey
Post by donkeychomp » Tue Feb 23, 2016 11:35 pm
The LC swingarm and shock arrived. Swinger fits perfectly to the RD frame but there are many issues. Some lugs will have to come off the frame for the shock to fit and even though it appears the wheel fits this is without the chain adjusters fitted. It needs widening. I'm thinking a bit of heat and move it out a tad...only 4mm. Mounts will need to be welded to the RD frame to accept the LC shock too.
The shock looks awful but it will clean up and has anyone got an idea of how to compress it so I can take it apart?
Oh...and the headlight. Way too high I will lower it!
