Gilly_SJ
Post
by Gilly_SJ » Sun Feb 28, 2016 8:33 pm
New to the 4x4 world and just purchased my first Suzuki. A 1986 SJ 413 Estate! Pretty well specced with add a leaf, 3" shackles, 15 inch fourtrak wheels and Insa Turbo specials.
Bought with a half assed 1.6 and SU conversion which I'm plotting through to get running. To give you an idea of how half assed, the plug order was wrong and he had one of the radiator hoses running to the brake servo vac take off on the manifold.
Once I get an idea of the right rebuild kit for the SU I'll hopefully get to drive it!
Post
by ROBBIE » Mon Feb 29, 2016 8:31 am
Hi
Enjoy the build. Any problems ask they are a good bunch of lads on here who know all there about these little monsters. I dont count myself as one
Post
by Jordi » Mon Feb 29, 2016 6:20 pm
Can't help but notice the northeastlaners sticker.
Where abouts are you?
Gilly_SJ
Post
by Gilly_SJ » Mon Feb 29, 2016 7:34 pm
They were on it when I got it but I'm based in aycliffe, few of us got jeeps here now.
Mainly go to hamsterly but looking for other places
Post
by Jordi » Mon Feb 29, 2016 8:21 pm
Quite a few good lanes up northumberland, haltwhistle way.
Don't do much locally sadly, work always gets in the way.
Post
by twiss » Mon Feb 29, 2016 8:43 pm
You should take the top off the carb, and take the needle and spring out to check they are correct. You could spend hours screwing about with it and not get anywhere.
The needle should have "BDL" on it and the spring should have a bit of yellow paint on one end
Post
by Anton » Mon Feb 29, 2016 8:53 pm
Good looking SJ! Nice to see another new SJ fan, welcome to the forums!
Gilly_SJ
Post
by Gilly_SJ » Tue Mar 01, 2016 10:00 am
twiss wrote:You should take the top off the carb, and take the needle and spring out to check they are correct. You could spend hours screwing about with it and not get anywhere.
I've fitted a BDL and yellow spring but the original was a BFM/red so shouldn't have been causing any issues really.
My problems lie with the throttle spindle and bushings, and possibly the overrun valve. Burlen has a rebuild kit en-route as we speak,
Post
by twiss » Tue Mar 01, 2016 2:28 pm
Get rid of the overrun valve and replace with a solid disc. Those valves are known for causing problems
SlimGrim
- Winching along now
Post
by SlimGrim » Tue Mar 01, 2016 6:41 pm
Welcome
Looks really good! Hopefully you'll get her on the road soon bud!
___________________
