Rocker cover boltss , no where to be found ...
Ryebeck
Post by Ryebeck » Thu May 05, 2016 8:29 am
Morning
Just wondering if somebody has a link of where to i can get the 4 rocker cover bolts for my sj413 , i just noticed an oil leak from the front corner and went to nip up the bolts but the front left one was sheared off :oops: when i went to tighten it ..... I have tried ebay but nothing but Gaskets but no bolts :cry:
and anybody know what torque these should be set to ?
My approach of tight and re-tight didn't work this time :hahaha:
thanks
[color=#FF0040][b][i]Getting there with some new Monster Truck Mods [/i][/b][/color]
Jazza
Re: Rocker cover boltss , no where to be found ...
Post by Jazza » Thu May 05, 2016 4:09 pm
Jazza
Post by Jazza » Thu May 05, 2016 4:12 pm
Here is a great page for torque info:
http://www.suzukiclubuk.co.uk/tech-spec ... olt-torque
Post by Darrell » Thu May 05, 2016 7:42 pm
I can't find any for sale online :thumbdown:
SJ 413 rock cover bolts.jpg (201.69 KiB) Viewed 9269 times
Post by donkeychomp » Thu May 05, 2016 9:06 pm
You could try Suzuki UK or ask someone here who's breaking an SJ. As for tightening them just do them up and not too much either. They certainly don't need torquing down!
Post by dan_2k_uk » Thu May 05, 2016 9:37 pm
Theres a small chance I might have some if you can't find any new ones. I will have to have a good hunt if so.
SherwoodNash
Post by SherwoodNash » Thu May 05, 2016 11:05 pm
About £20 from the states on Ebay, probably not a lot more though from your local main dealer?
Valve Cover Bolt & Washer Set
http://www.ebay.co.uk/itm/301880144839
Ryebeck
Post by Ryebeck » Wed May 11, 2016 11:19 am
SherwoodNash wrote:About £20 from the states on Ebay, probably not a lot more though from your local main dealer?
Thanks ill check these out , a bit pricey for a bolt when you add the carriage but i suppose there worth it , thanks for all the help :D
Ryebeck
Post by Ryebeck » Wed May 11, 2016 11:21 am
Darrell wrote:I can't find any for sale online :thumbdown:
Yup neither can i except from the states , i am wondering would some 6mm s/s treaded bar do the job instead .. :S
Post by ScottieJ » Wed May 11, 2016 4:27 pm
I have loads of spare ones :thumbup:
