Rocker cover boltss , no where to be found ...
Morning
Just wondering if somebody has a link of where to i can get the 4 rocker cover bolts for my sj413 , i just noticed an oil leak from the front corner and went to nip up the bolts but the front left one was sheared off when i went to tighten it ..... I have tried ebay but nothing but Gaskets but no bolts
and anybody know what torque these should be set to ?
My approach of tight and re-tight didn't work this time
thanks
thanks
[color=#FF0040][b][i]Getting there with some new Monster Truck Mods [/i][/b][/color]
Re: Rocker cover boltss , no where to be found ...
Is this what you are looking for:
http://www.autodoc.co.uk/car-parts/cyli ... 413/sierra
Here is a great page for torque info:
http://www.suzukiclubuk.co.uk/tech-spec ... olt-torque
I can't find any for sale online
- SJ 413 rock cover bolts.jpg (201.69 KiB) Viewed 8809 times
- donkeychomp
You could try Suzuki UK or ask someone here who's breaking an SJ. As for tightening them just do them up and not too much either. They certainly don't need torquing down!
Theres a small chance I might have some if you can't find any new ones. I will have to have a good hunt if so.
- Winching along now
About £20 from the states on Ebay, probably not a lot more though from your local main dealer?
Valve Cover Bolt & Washer Set
http://www.ebay.co.uk/itm/301880144839
SherwoodNash wrote:About £20 from the states on Ebay, probably not a lot more though from your local main dealer?
Thanks ill check these out , a bit pricey for a bolt when you add the carriage but i suppose there worth it , thanks for all the help
Yup neither can i except from the states , i am wondering would some 6mm s/s treaded bar do the job instead ..Darrell wrote:I can't find any for sale online
I have loads of spare ones
