Those spring loaded brake shoe retaining pins....
Eltoon
Post by Eltoon » Sun Mar 12, 2017 9:45 am
The pins that go through the back of the drum and through the middle of the shoe then have the spring over them and retained by a little disc with a slot so you have to somehow hold the shoe in place, hold the pin in place, compress the spring and fit the little disc then twist the pin or the disc 90 degrees to hold it. How the feckity bastard feck do you get those fecking bastard feckers back on? :bawling: :argh: :oops:
palo123
Re: Those spring loaded brake shoe retaining pins....
Post by palo123 » Sun Mar 12, 2017 9:58 am
You fit rear discs instead haha :lol:
Post by Jordi » Sun Mar 12, 2017 12:19 pm
perseverance.
Eltoon
Post by Eltoon » Sun Mar 12, 2017 1:25 pm
It's perseverance wot done it. Blue-tacked the disc to the end of me pliers. I've since discovered there is a tool specially made for those buggers. Maybe I'll get one before I do the other side.......once my wounds have healed...
Post by ROBBIE » Sun Mar 12, 2017 2:20 pm
Hold cap with pliers, with free hand hold pin on rear of plate. Push cap in with pliers, rotate pin with other hand
SZ5
Post by SZ5 » Sun Mar 12, 2017 4:09 pm
Just washed, not a leak from the engine!
Post by ScottieJ » Sun Mar 12, 2017 6:47 pm
I just use needle nose pliers. Hold the back of the pin push the cap on until you can grip the pin, then use your hand to hold disc while you spin the pin with the pliers.
Easy once you learn the technique
