Eltoon
Post
by Eltoon » Sun Mar 12, 2017 9:45 am
palo123
Post
by palo123 » Sun Mar 12, 2017 9:58 am
You fit rear discs instead haha
Post
by Jordi » Sun Mar 12, 2017 12:19 pm
perseverance.
Eltoon
Post
by Eltoon » Sun Mar 12, 2017 1:25 pm
It's perseverance wot done it. Blue-tacked the disc to the end of me pliers. I've since discovered there is a tool specially made for those buggers. Maybe I'll get one before I do the other side.......once my wounds have healed...
Post
by ROBBIE » Sun Mar 12, 2017 2:20 pm
Hold cap with pliers, with free hand hold pin on rear of plate. Push cap in with pliers, rotate pin with other hand
SZ5
Post
by SZ5 » Sun Mar 12, 2017 4:09 pm
Just washed, not a leak from the engine!
- The Boss
Post
by ScottieJ » Sun Mar 12, 2017 6:47 pm
I just use needle nose pliers. Hold the back of the pin push the cap on until you can grip the pin, then use your hand to hold disc while you spin the pin with the pliers.
Easy once you learn the technique
