Power steering options
Gardiner
Post by Gardiner » Mon Jul 10, 2017 8:16 am
Hi all what are the options for a SJ to put power steering on.
I got a SJ with a 5" Calmini full suspension lift.
Thanks in advance
zook123
Re: Power steering options
Post by zook123 » Mon Jul 10, 2017 8:31 am
As I popped in your other post, Jimny PS will fit.
http://forum.suzukiclubuk.co.uk/vi ... php?t=1634
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Gardiner
Post by Gardiner » Mon Jul 10, 2017 11:51 am
So will the pump off a jimny or vitara bolt ok to block of a 413 and what bottom pulley and Pittman arm issues might I encounter
Post by ScottieJ » Mon Jul 10, 2017 12:11 pm
The pump mount off an Vit G16 8v engine fits.
You will need to tweak the rad mount on the chassis though for the pump pulley clearance.
If you have a drop pitman arm with your calmini lift kit then it will not fit the jimny box, I don't think there's a drop pitman arm available for the jimny box.
If you aren't running a drop pitman arm then the stock jimny pitman arm will be pretty much the same steering geometry wise as the stock sj pitman.
Gardiner
Post by Gardiner » Mon Jul 10, 2017 12:48 pm
I think there is a drop pitman arm on her i bought it with kit on and when i look on calmini website it comes with one so what would the next option be ??
Curtisflip
Post by Curtisflip » Fri Sep 01, 2017 12:32 am
I added electric steering, easy fab to do and reasonable cost. Here is a link to my write up.
http://bbs.zuwharrie.com/content?topic=134451.0
https://www.youtube.com/watch?v=90e4fUhcH_4
86 Samurai, 2" suspension lift, 29" Mud Tires, 6.5 to 1 t-case, rear spool, full internal cage. Driven by partially trained Chimp.
tomcat
Post by tomcat » Sun Jan 28, 2024 2:46 pm
Can I revive this thread with a question.
Have purchased a PAS system from a Jimny.
The engine mount for the PAS pump is as the attached pictures.
It does not seem to fit my G13A Santana Samurai engine. What am I getting wrong?
Post by ScottieJ » Sun Jan 28, 2024 4:56 pm
Was the set up and mount from a Jimny with an M series engine? You need a mount from a vitara G16 8v engine. It’s still not always a straight bolt on swap though as it can be tight for chassis clearance
tomcat
Post by tomcat » Sun Jan 28, 2024 6:46 pm
Scott
Your comments noted. Thanks.
