parrots trak
parrotveasey81
Re: parrots trak
Post by parrotveasey81 » Sat Nov 20, 2010 5:29 pm
got a bit more done today
parrotveasey81
Re: parrots trak
Post by parrotveasey81 » Sat Nov 20, 2010 5:31 pm
3 pics andall in backwards order :twisted:
Re: parrots trak
Post by Edweird » Sat Nov 20, 2010 6:58 pm
Hey, nice work. That'll look pretty smart when it's done. What did you cut up for the inside wheelarch?
parrotveasey81
Re: parrots trak
Post by parrotveasey81 » Sat Nov 20, 2010 8:06 pm
Edweird wrote:Hey, nice work. That'll look pretty smart when it's done. What did you cut up for the inside wheelarch?
thanks,i have cut out the inner arch due to the tyres catching on the up travel and as i want more up travel i need more room,the joys of a virtual lift :roll: it may keep the truck low but brings alot of work if you want flex,at the moment i have 2" of up travel and 8" of down travel on the shocks and i would like 4"-6" of up travel as well as 8" of down travel 8-)
Re: parrots trak
Post by Edweird » Sat Nov 20, 2010 9:51 pm
I meant what did you put in to fill the hole after you cut out the old arch. It looks like a panel fom somethingelse that's been cut up.
Yeah, I can see why you'd want more than 2" of up travel. I reckon that's probably about the standard movement with standard wheels, isn't it?
parrotveasey81
Re: parrots trak
Post by parrotveasey81 » Sun Nov 21, 2010 7:43 am
[/quote]
Yeah, I can see why you'd want more than 2" of up travel. I reckon that's probably about the standard movement with standard wheels, isn't it?[/quote]
oh right,standard it has more than 2" up travel but i had to limit that to 2" because the tyres are 6"s taller overall and i only have a 2" spring lift
first pic with standard size tyre,29" tall and secound pic with 33" tall tyre,im now running 35"tyres
parrotveasey81
Re: parrots trak
Post by parrotveasey81 » Sun Nov 21, 2010 7:46 am
this is how i filled the gap.its just sheet steel cut to shape
parrotveasey81
Re: parrots trak
Post by parrotveasey81 » Sun Nov 21, 2010 4:29 pm
got the inside of the cab sealed today,now lets see if i can get the pics the right way around :roll:
Re: parrots trak
Post by Jordi » Sun Nov 21, 2010 4:34 pm
Now that is a rather spiffy looking conversion. It all looks so neat and tidy compared to when I did mine.
Gona run the Zuk to xmas and hopefully get some garage time while Im off and tidy the bits you can't see up, I'm fairly sure these are where it's leaking.
Keep up the good work.
Re: parrots trak
Post by ScottieJ » Sun Nov 21, 2010 10:54 pm
Looking good Parrot :smoke: tidy work as usual.
