parrots trak
- Can I have a tow
Re: parrots trak
got a bit more done today
- 001.jpg (65.32 KiB) Viewed 8164 times
- 005.jpg (54.52 KiB) Viewed 8164 times
- 009.jpg (70.79 KiB) Viewed 8166 times
- Can I have a tow
Re: parrots trak
3 pics andall in backwards order
- 011.jpg (57.75 KiB) Viewed 8160 times
- 014.jpg (63.71 KiB) Viewed 8161 times
- 043.jpg (40.93 KiB) Viewed 8162 times
- Edweird
Re: parrots trak
Hey, nice work. That'll look pretty smart when it's done. What did you cut up for the inside wheelarch?
- Can I have a tow
Re: parrots trak
Edweird wrote:Hey, nice work. That'll look pretty smart when it's done. What did you cut up for the inside wheelarch?
thanks,i have cut out the inner arch due to the tyres catching on the up travel and as i want more up travel i need more room,the joys of a virtual lift
- Edweird
Re: parrots trak
I meant what did you put in to fill the hole after you cut out the old arch. It looks like a panel fom somethingelse that's been cut up.parrotveasey81 wrote:Edweird wrote:Hey, nice work. That'll look pretty smart when it's done. What did you cut up for the inside wheelarch?
thanks,i have cut out the inner arch due to the tyres catching on the up travel and as i want more up travel i need more room,the joys of a virtual liftit may keep the truck low but brings alot of work if you want flex,at the moment i have 2" of up travel and 8" of down travel on the shocks and i would like 4"-6" of up travel as well as 8" of down travel
Yeah, I can see why you'd want more than 2" of up travel. I reckon that's probably about the standard movement with standard wheels, isn't it?
- Can I have a tow
Re: parrots trak
[/quote]
Yeah, I can see why you'd want more than 2" of up travel. I reckon that's probably about the standard movement with standard wheels, isn't it?[/quote]
oh right,standard it has more than 2" up travel but i had to limit that to 2" because the tyres are 6"s taller overall and i only have a 2" spring lift
first pic with standard size tyre,29" tall and secound pic with 33" tall tyre,im now running 35"tyres
- 25042010179.jpg (54.56 KiB) Viewed 8126 times
- 062.jpg (66.63 KiB) Viewed 8126 times
- Can I have a tow
Re: parrots trak
this is how i filled the gap.its just sheet steel cut to shape
- 030.jpg (47.12 KiB) Viewed 8124 times
- 033.jpg (40.93 KiB) Viewed 8124 times
- 041.jpg (35.05 KiB) Viewed 8124 times
- Can I have a tow
Re: parrots trak
got the inside of the cab sealed today,now lets see if i can get the pics the right way around
- 003.jpg (44.27 KiB) Viewed 8105 times
- 002.jpg (64.22 KiB) Viewed 8104 times
- 001.jpg (50.94 KiB) Viewed 8102 times
Re: parrots trak
Now that is a rather spiffy looking conversion. It all looks so neat and tidy compared to when I did mine.
Gona run the Zuk to xmas and hopefully get some garage time while Im off and tidy the bits you can't see up, I'm fairly sure these are where it's leaking.
Keep up the good work.
