215/75/15 will they fit?
tonsky
Post by tonsky » Mon May 21, 2012 8:22 am
Hi
Currently running 205/70/15 road tyres if I purchase 215/75/15 mud tyres will they fit?
I have no lift on my sj
Toni
ianedwards
Re: 215/75/15 will they fit?
Post by ianedwards » Mon May 21, 2012 11:45 am
i would have thought so. thats only a few mm bigger.
Ian
Ian. :)
Offroadrunner
Post by Offroadrunner » Mon May 21, 2012 3:57 pm
205/70/15 = 668 mm
215/75/15 = 787 mm
Difference of 19 mm, that should fit ;)
Groeten / Gruß / Regards / Salue / Salutare / Menyapa / 挨拶する, ]-[arold
http://www.offroadrunner.nl
http://www.suzukilj80.nl
tonsky
Post by tonsky » Mon May 21, 2012 4:30 pm
Fantastic thankyou both :D
Post by Edweird » Mon May 21, 2012 4:54 pm
Yes.
Post by Darrell » Mon May 21, 2012 9:18 pm
When I first got my sj I fitted 215r15 tyres with no lift and they rubbed on the front bumper mounting plates, however I just cut/ground the plate back to near the nut and bolt & they just missed. Just give it a good check before driving very far as this edge may cut into the tyre. They only rubbed with quite a bit of lock on.
Didn't need much cutting
charger
Post by charger » Thu May 31, 2012 7:29 am
I have 215/80/15 they rub on full lock
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
