Edweird wrote:Strip it out, get is painted 2 tone on the outside and white 'n' pine on the inside.
trotter wrote:nice purple upholstery
The purple upholstery was the first thing that was removed and burnt, also the four layers of nasty stained ply board on the floor
The floor under the ply was surprisingly good
As for strip it out and get it painted.. I think there'll be a little bit more to do than that, it has eleven coats of paint on it.
Started to remove some of the paint.Windows out, doors off, engine out.
Getting cold and wet now working on the drive..Also having windows removed and no security is a bad idea so started the search for a workshop..
A workshop big enough for the camper and the Suzuki.. Weeks of searching.. Found one
Hired a car transporter and moved the SJ first then the camper.
Got them in their new home the day after boxing day.. Now I can start work
In the last couple of pictures you can see there's a hole in the roof where a sunroof has been fitted.. Not happy about this.. Why would you cut a hole in a tintop camper?
Going to rectify this so I bought a front roof cut from a seventies T2 so I've got original steel with the original shape/bow.. Going to cut the panel, joggle the edge, weld from inside and have a go at lead loading the outside.
