![yuk :yuk:](./images/smilies/648134.gif)
You could not see the bloody springs and the whole rocker assembly was jet black. I set to work using Jizer, white spirit, Brake cleaner and anything else I could get my hands on to try and remove the crud! Ive used flat headed screwdrivers to loosen the crud, wire brushes and it is beginning to look a bit better.
I had not planed to do major engine work so this has been a setback. Having cleaned much of the crap off (with the head still bolted on) I can now see the cam. It looks like the last lobe of the cam is badly worn (near the back of the engine) so I need to find a replacement cam
![Crying or Very Sad :cry:](./images/smilies/icon_cry.gif)
Can anyone recommend a place to pick up one at a reasonable cost?
Have to say the costings on this thing now are beginning to spiral, not what I planed at all :(
