Mixture screw on a 413
Re: Mixture screw on a 413
Post by Darrell » Fri Jun 28, 2013 10:48 pm
That fleabay tool looks nothing like the one in the manual.........
carb tool.png (24.77 KiB) Viewed 16895 times
Post by turbo-tom » Fri Jun 28, 2013 10:51 pm
that ebay one looks nothing like it! :er:
Looks like its main stealer time!
Post by Darrell » Fri Jun 28, 2013 10:56 pm
If I can't bodge it, it's staying like it :D
Post by turbo-tom » Fri Jun 28, 2013 10:59 pm
And if you cant bodge it looks like your going to the su! ;)
Post by ScottieJ » Sat Jun 29, 2013 9:49 am
I've done it by just wedging a flathead screwdriver of the correct size down between the collar and adjuster before.
Post by Darrell » Sat Jun 29, 2013 9:12 pm
Well I managed to turn it with a small flathead bit in a 1/4" spanner jammed in the gap. I right pain to do though !!
I turned it in and it only got worse, so undid it some and it didn't get any better than I started with.
Then dropped the bit, never to be seen again :argh:
So thought, stuff it then :thumbup:
Still ticks over rough but checking the CO2 it's 1.3 according to my tester so that's all it's getting..
Bloody rust bucket............
Post by turbo-tom » Sat Jun 29, 2013 9:15 pm
ah man i hate it when i loose them little bits! be fine for the mot though! remember rust is lighter then carbon fibre! ;)
Post by Jordi » Sat Jun 29, 2013 9:19 pm
turbo-tom wrote:remember rust is lighter then carbon fibre! ;)
Full of helpful info as always Tom.
Frenchy
Post by Frenchy » Thu Dec 14, 2023 10:39 am
Mine passes the emissions test every year but just occasionally I get the petrol smell. It won't idle at 800 rpm (very choppy) seems to settle at 1000. I'm loath to start messing with botched tools that might make things worse. Maybe a new set of plugs?
kiwitony
Post by kiwitony » Fri Dec 22, 2023 7:48 pm
Making this tool may help: Alan Millyard made a bent screwdriver for adjusting carburettor screws on his motorbike - detailed video here: https://youtu.be/AZCxYTc4axY?feature=shared "In this video I show how I made a simple flexible screwdriver to adjust the mixture screws on my Honda ST1100 pan European. The mixture screws can not be accessed with a conventional straight screwdriver."
