Mixture screw on a 413
Re: Mixture screw on a 413
That fleabay tool looks nothing like the one in the manual.........
- carb tool.png (24.77 KiB) Viewed 16898 times
- turbo-tom
that ebay one looks nothing like it!
Looks like its main stealer time!
Tom
Ford Fiesta ST
Ford Fiesta ST
If I can't bodge it, it's staying like it
- turbo-tom
And if you cant bodge it looks like your going to the su!
Tom
Ford Fiesta ST
Ford Fiesta ST
I've done it by just wedging a flathead screwdriver of the correct size down between the collar and adjuster before.
Well I managed to turn it with a small flathead bit in a 1/4" spanner jammed in the gap. I right pain to do though !!
I turned it in and it only got worse, so undid it some and it didn't get any better than I started with.
Then dropped the bit, never to be seen again
So thought, stuff it then
Still ticks over rough but checking the CO2 it's 1.3 according to my tester so that's all it's getting..
Bloody rust bucket............
- turbo-tom
ah man i hate it when i loose them little bits! be fine for the mot though! remember rust is lighter then carbon fibre!
Tom
Ford Fiesta ST
Ford Fiesta ST
Full of helpful info as always Tom.turbo-tom wrote:remember rust is lighter then carbon fibre!
Mine passes the emissions test every year but just occasionally I get the petrol smell. It won't idle at 800 rpm (very choppy) seems to settle at 1000. I'm loath to start messing with botched tools that might make things worse. Maybe a new set of plugs?
Making this tool may help: Alan Millyard made a bent screwdriver for adjusting carburettor screws on his motorbike - detailed video here: https://youtu.be/AZCxYTc4axY?feature=shared "In this video I show how I made a simple flexible screwdriver to adjust the mixture screws on my Honda ST1100 pan European. The mixture screws can not be accessed with a conventional straight screwdriver."
