theoretical long drive
Re: theoretical long drive
Post by twiss » Thu Jan 23, 2014 11:52 pm
Maybe use a whole axle case... do you reckon you could power some kind of genny to charge up batteries while going along
Post by Jordi » Thu Jan 23, 2014 11:56 pm
twiss wrote:Maybe use a whole axle case... do you reckon you could power some kind of genny to charge up batteries while going along
As Scottie pointed out a whole axle would need a diff in, unless you just fitted stub axles, then the diff housing might foul and cause unwanted dragging.
Post by Anton » Fri Jan 24, 2014 2:00 am
twiss wrote:do you reckon you could power some kind of genny to charge up batteries while going along
Cheap solar panel? Charging off the alternator uses extra fuel...
Jordi wrote:As Scottie pointed out a whole axle would need a diff in, unless you just fitted stub axles, then the diff housing might foul and cause unwanted dragging.
Two stub axles welded to a thick piece of box section could work? You'd have to be careful to get everything lined up properly (not sure I have that level of skill) but it should be possible.
Or maybe you could make it so it bolts on to the box section "axle"?
Then drill holes in the bottom of the box section and use standard SJ leafs. You wouldn't even need to make perches, just get square U bolts and make a retaining plate. Add shock mounts. Boom. Done.
Post by ScottieJ » Fri Jan 24, 2014 11:21 am
NylonAdmiral and myself are planning a possible trip next year down through france and into Italy via the Hannibal trail through the Alps if anyone is interested. Possibly returning via Austria and Switzerland so we can go play on a few Alpine coasters :rockin:
Anyone else interested?
timwilks13
SCUK Website Padawan
Post by timwilks13 » Fri Jan 24, 2014 11:27 am
That would be an incredible trip, good handful of SJ's all in convoy through the alps. That would create an album worth keeping.
Post by twiss » Fri Jan 24, 2014 11:29 am
I want to drive up an Alp!!!
Yeah you're right about that one Tim... one to show the grand kids haha
Post by andyrew » Fri Jan 24, 2014 3:13 pm
ScottieJ wrote:NylonAdmiral and myself are planning a possible trip next year down through france and into Italy via the Hannibal trail through the Alps if anyone is interested. Possibly returning via Austria and Switzerland so we can go play on a few Alpine coasters :rockin:
Guess ill have to keep the lwb a bit longer then :lol:
marshall
Post by marshall » Thu Jan 30, 2014 8:17 pm
I would certainly recommend you give the old girl a once over and make sure that everything is in running order. Other than making sure she is in good running order I can't imagine you should have anything else to worry about. I would suggest packing extra supplies in the vehicle just in case you find yourself in a tough situation, but with a caravan you should easily have extra supplies already. The only other recommendation that I would have is to just do it. Whatever arises you will find a solution for, and no matter what may arise you will create memories.
timwilks13
Post by timwilks13 » Thu Jan 30, 2014 8:24 pm
Caravan idea is well out the window as just seems more hassle than its worth, so probably taking a small trailer with spares etc. The Asia bit might be being replaced with south Africa now, as China really don't make it easy to get in!! Will have it ready long before we go, plenty of time to break it in, break it, and fix it.
Marc
Post by Marc » Thu Jan 30, 2014 9:05 pm
timwilks13 wrote:, so probably taking a small trailer with spares etc. The Asia bit might be being replaced with south Africa now, as
are you talking about driving to South Africa, I did the trip on an overland truck not an easy trip but great fun
