WANDERING STEERING
roll_cage
WANDERING STEERING
Post by roll_cage » Fri Feb 05, 2010 8:28 pm
Hello everyone, I have a santanna sj410 which is faultless (not being to cockey) :lol: ... but my brothers just bought a sj 413 which seems to wander on the road, could it be the shackle lifts?
Pugsley
Re: WANDERING STEERING
Post by Pugsley » Fri Feb 05, 2010 10:35 pm
roll_cage wrote:Hello everyone, I have a santanna sj410 which is faultless (not being to cockey) :lol: ... but my brothers just bought a sj 413 which seems to wander on the road, could it be the shackle lifts?
Could be so many things - lifting the body will tend to make the vehicle less stable but check the wheel bearings for wear/slack, suspension bushes, steering geometry, distorted brake discs, king pin wear, chassis distortion and I'm sure that more experienced members will add to my list.
Post by Tramp » Fri Feb 05, 2010 11:34 pm
yes, if it has lift shackles on the front they tend to 'wander' and can induce 'bump steer' which is a pain in the arse, also those lift shackles can fook your front springs up if your not careful,
Post by ROBBIE » Sat Feb 06, 2010 7:49 am
id also check the u-bolts arnt loose on the front axel
muddy kev
Post by muddy kev » Sat Feb 06, 2010 8:19 am
has it got wheel spacers or off set rims? cos if u go up u should go out as well.
also simple check to do if u gently move the steering wheel how much movement b4 wheels start 2 move as could be to much play in steering box. u can adjust that out with the small screw on top of the box.
cheers kev
roll_cage
Post by roll_cage » Sun Feb 07, 2010 4:52 pm
Thanks everyone I'll tell him its probably the shackles lifts they look fairly dogey
Post by Tramp » Mon Feb 08, 2010 12:28 am
roll_cage wrote:Thanks everyone I'll tell him its probably the shackles lifts they look fairly dogey
ha! they usually are! If you look while its sitting on the flat alot of the lifted shackles lean the car over to one side, so if you think about it when your driving it must throw the axle from one side of the lean to the other, and thats why they are pretty shakey on the road, Im not saying all lift shackles are bad though, especially if they are used properly and on the back axle, also some of them ebay jobbies don't really seem up to it,
Luke
Post by ScottieJ » Mon Feb 08, 2010 11:36 am
also jack the front end up and check for play in the wheel bearings and kingpin bearings.
