NYLON CABLE TIES
jim tylee
NYLON CABLE TIES
Post by jim tylee » Thu May 01, 2014 10:29 am
When i first got my 413 Suzuki the rear springs were very dry squeaky as well so i thought i would lace a couple of cable ties between the leaves at the ends this did the trick no more squeaks..it lasted for quite a while as well similar i guess to some springs that have a nylon button in the same place.....only just remembered this could have saved all the Waxoyl spray which did not last.
Jim
jim tylee
Re: NYLON CABLE TIES
Post by jim tylee » Fri May 02, 2014 9:58 am
jim tylee wrote:When i first got my 413 Suzuki the rear springs were very dry squeaky as well so i thought i would lace a couple of cable ties between the leaves at the ends this did the trick no more squeaks..it lasted for quite a while as well similar i guess to some springs that have a nylon button in the same place.....only just remembered this could have saved all the Waxoyl spray which did not last.
Jim
Anyone else think that was a good idea...??????
JIM
jim tylee
Jim
JIM
mk1joe
Post by mk1joe » Sat May 03, 2014 1:27 pm
Sure, why not. If it works, cant ask for more than that.
