When i first got my 413 Suzuki the rear springs were very dry squeaky as well so i thought i would lace a couple of cable ties between the leaves at the ends this did the trick no more squeaks..it lasted for quite a while as well similar i guess to some springs that have a nylon button in the same place.....only just remembered this could have saved all the Waxoyl spray which did not last.
Jim
NYLON CABLE TIES
Re: NYLON CABLE TIES
Anyone else think that was a good idea...??????jim tylee wrote:When i first got my 413 Suzuki the rear springs were very dry squeaky as well so i thought i would lace a couple of cable ties between the leaves at the ends this did the trick no more squeaks..it lasted for quite a while as well similar i guess to some springs that have a nylon button in the same place.....only just remembered this could have saved all the Waxoyl spray which did not last.
Jim
JIM
Jim
JIM
Sure, why not. If it works, cant ask for more than that.
