hey again everyone.
i have a mamoth task, i need to swap my over under axle conversion from one anus to another.
how easy is this....?
will upload photos of both unber sides if nessercary.
i really dont want to undertake this alone... as i have no idea were to start...
any help would be greatly apprecieated.
Russ.
swapping suspension from anus to anus - how easy
Re: swapping suspension from anus to anus - how easy
Complete axle swap, not a mamoth task, couple of hours max if all bolts/nuts are a ok! ![Cool 8-)](./images/smilies/icon_cool.gif)
- Russ24
- Can I have a tow
cheers hnery
sized it up earlier.
removed prop's and disconnected brake lines and hand brake cable....
going to use a forklift to raise the jeeps at the critical moment.
so hopefully next weekend things shall be sorted.
need to put some of the old crap back on the dead anus in order to move it.
then i shall remove the rad, and few parts like that and then its up for grabs.
- 13032010166 edit small.jpg (163.63 KiB) Viewed 5824 times
![Image](http://farm9.staticflickr.com/8056/8438645884_b2df455aac_z.jpg)
![russ's sj side :russ:](./images/smilies/russ-gif.gif)
I would give it a bloody good powerwash before you get under it! ![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
- Russ24
- Can I have a tow
henry-the-hoover wrote:I would give it a bloody good powerwash before you get under it!
clean it? me? clean stuff? never!! hahaa
hopefully this weekend i should finish this swapping melarky.
- Russ24
- Can I have a tow
i have hit a sticky point.. damnedest thing..... i have a 48" lift jack.
BUT, i havent got any axle stands or anything to support TWO jeeps high enough while i swap over the axles......
been looking for axle stand about 3ft roughly OR something that will support body work while i remove said axleS!!!
any help plaese.
any help plaese.
- Russ24
- Can I have a tow
i have completed the swap.
few problems as expected.
however the taller is is now.. i have put the standard shocks back on...
maybe uprating would be a good idea.
suggestions on shocks please.
- the stripping will continue
- 18042010222 small.jpg (177.72 KiB) Viewed 5697 times
- 18042010226 small.jpg (148.54 KiB) Viewed 5696 times
- WHAT IM AIMING FOR :P
- Dscf6397 going postal edit.jpg flat SMALL.jpg (168.08 KiB) Viewed 5688 times
