swapping suspension from anus to anus - how easy
Russ24
Post by Russ24 » Sun Mar 14, 2010 12:42 pm
hey again everyone.
i have a mamoth task, i need to swap my over under axle conversion from one anus to another.
how easy is this....?
will upload photos of both unber sides if nessercary.
i really dont want to undertake this alone... as i have no idea were to start...
any help would be greatly apprecieated.
Russ.
:russ:
Henry
Re: swapping suspension from anus to anus - how easy
Post by Henry » Sun Mar 14, 2010 12:59 pm
Complete axle swap, not a mamoth task, couple of hours max if all bolts/nuts are a ok! 8-)
Russ24
Post by Russ24 » Sun Mar 14, 2010 7:49 pm
cheers hnery
sized it up earlier.
removed prop's and disconnected brake lines and hand brake cable....
going to use a forklift to raise the jeeps at the critical moment.
so hopefully next weekend things shall be sorted.
need to put some of the old crap back on the dead anus in order to move it.
then i shall remove the rad, and few parts like that and then its up for grabs.
13032010166 edit small.jpg (163.63 KiB) Viewed 6223 times
:russ:
Henry
Post by Henry » Wed Mar 17, 2010 4:23 pm
I would give it a bloody good powerwash before you get under it! :twisted:
Russ24
Post by Russ24 » Wed Mar 17, 2010 6:42 pm
henry-the-hoover wrote:I would give it a bloody good powerwash before you get under it! :twisted:
clean it? me? clean stuff? never!! hahaa
hopefully this weekend i should finish this swapping melarky.
:russ:
Russ24
Post by Russ24 » Fri Apr 02, 2010 3:41 pm
i have hit a sticky point.. damnedest thing..... i have a 48" lift jack.
BUT, i havent got any axle stands or anything to support TWO jeeps high enough while i swap over the axles......
been looking for axle stand about 3ft roughly OR something that will support body work while i remove said axleS!!!
any help plaese.
:russ:
Russ24
Post by Russ24 » Mon Apr 19, 2010 11:39 pm
i have completed the swap.
few problems as expected.
however the taller is is now.. i have put the standard shocks back on...
maybe uprating would be a good idea.
suggestions on shocks please.
the stripping will continue
18042010222 small.jpg (177.72 KiB) Viewed 6096 times
18042010226 small.jpg (148.54 KiB) Viewed 6095 times
WHAT IM AIMING FOR :P
Dscf6397 going postal edit.jpg flat SMALL.jpg (168.08 KiB) Viewed 6087 times
:russ:
