muddymessers build thread
- muddymesser
Re: muddymessers build thread
well ebay happened again and ive just bought another 2 goodyear wrangler MTR's for the zook
i think im just going to risk the rear diff for a while . . . maybe take it out and take some slack out of it etc at least untill i can buy a new one
- muddymesser
Mot tomorrow
- muddymesser
well the mot was a fail on afew little things
front discs were pitted pretty badly as it had been stood for a while
rear damper was loose
hand brake wanted adjusting
emissions
and there is a small rust hole in each sill :/
also while swapping tyres over the other day i noticed who ever fitted my road tyres fecked up my wheel stud extensions and some of my nuts
so this weekend ive sorted the damper, hand brake, front discs, ordered a welding mask a bunch of new stud extensions and a set of wheel nuts
and the mot guy said he'll sort my emissions out for me
emissions
- muddymesser
not much progress has been made
but i've got my window de-mist vents re-attached and the speedo cable re routed so it might work now
also got the drivers side air vent re-attached at the same time and wired in my sat nav wire permanently after i broke the fag socket plug some how, a new ignition coil is on its way so might help it with emissions a bit and ive got all the welding the mot man said it needed and then some more . . . a 5cm square plate turned into 13 inch by 13 cm
had to drill a hole in the lowest point of my snorkel after the mad rain recently and im glad i did
got a new rear section of exhaust made up with removable tips just in-case i squish one when im playing, plus it sounds alot better than the drift cannon i had there before
oh and ive fixed the cover behind the steering wheel too
- muddymesser
Afew pics
- DSC_0133.JPG (1.87 MiB) Viewed 7213 times
- DSC_0132.JPG (1.84 MiB) Viewed 7213 times
- FB_IMG_1408284805333.jpg (1.71 MiB) Viewed 7213 times
- DSC_0100.JPG (1.98 MiB) Viewed 7213 times
- DSC_0098.JPG (2.16 MiB) Viewed 7213 times
- received_m_mid_1407435094213_603d2adeaae4ba8e78_0.jpeg (70.79 KiB) Viewed 7213 times
- DSC_0057.JPG (1.59 MiB) Viewed 7213 times
- Ladaman
- Suzuki Guru
muddymesser wrote:had to drill a hole in the lowest point of my snorkel after the mad rain recently and im glad i did
- muddymesser
forgot to say
i put a screw with a rubber washer in the hole to act as a drain plug so i can let any water out of it that gets in there before i use it
You could install a one-way valve in the hole so that water can drain out but not get back in.
Or a ball valve so you can just leave it open when not using.it.
Best solution would be to get a better snorkle top though.
- muddymesser
i think i might just be disconnecting the snorkel when not in use .... especially when it starts freezing again . . . last time the filter on the snorkel actually froze up on the motorway
