Hi all,
Does anyone have an exploded diagram of front and rear suspension from a 410? or anything else thats the same? I want to count the bushes and things and see how it goes together before i have a go at replacing them all. Cheers
Courior
sj410 Suspension Diagram
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
5 speed box
1.5" Shackle Lift
Daymaker led lights
Re: sj410 Suspension Diagram
Done this..
The bolts that go through the spring/sleeve can often rust together so bad that they need to be cut off.
Just consider if you can get new bolts easily before you start. They are just 12mm x 100mm long.
Your of course may well be rust free !!
- Sj suspension bushes.jpg (163.37 KiB) Viewed 7669 times
Its ok.. Found a spring replacement guide in the how-to section for the front... i guess the rear is the same.. so 16 small bushes and 8 large ones, and 12 bolts in total. Correct me if im wrong
Now i see the Diagram.. So i was right, thats good
Cheers Darrell.
Going to make up some slightly longer shackles and get a kit to do this!
Cheers!
Courior
Cheers!
Courior
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
5 speed box
1.5" Shackle Lift
Daymaker led lights
The original shackles have special bolts so they pinch up tight but do not compress the bush. These are also pressed into the shackle plate.
When people make extended shackles I believe they just use bolts. I don't know if they weld the head to stop the bolt from turning in the shackle? and use nylock nuts as not to compress the bushes?
I recommend you only extend them a little if you go down this route.
- Standard shackle bolts.jpg (85.32 KiB) Viewed 7659 times
Yeah I recommended 100mm distance max to courior...
My bolt heads aren't welded in, but I have got nylock nuts. Never had a problem with them like that
I just do them up to the point just before they start to bend the shackles in
Bolt welded though the middle also helps
Yeah this was all twiss's idea lol. How thick does the steel plate need to be? Would going thicker than standard be of advantage?
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
5 speed box
1.5" Shackle Lift
Daymaker led lights
No need for a brace in the middle of the shackle, not having a brace allows the shackle to twist a bit and this helps with flex.
Helps to stop you doing them up to tight at least
And I find that mine flex even with the bar welded through the middle
