vitara sort out
Re: vitara sort out
Post by donkeychomp » Thu Apr 24, 2014 11:43 pm
Nice work!
shredder
Re: vitara sort out
Post by shredder » Sat Apr 26, 2014 8:38 pm
well went out this morning got me some wire (and spare gas cos you know what would happen if I didn't!) and finished off the boot :weld:
as you can see more rust along the bottom of the doorframe so patched up the two larger holes and was left with this
thinking to myself how in the hell do I fill that :er: well this is what I came up with seems to do the job! :D
so that's the boot done :doublethumbs:
however.. this is what I found underneath the carpets at the back! even more tin worm! :evil:
cut away the rot bits to leave this
another conundrum how do I work with the body mount?? well this is what I've thought, here's my template where the arrow is is the top of the bolt of the mount gonna cut a hole in the plate and weld round it here think that should do it?
the other side also rusted in same spot! but thankfully not as bad! I must admit when I saw this hole first I did think its ebay for you!! :pissed: but I think I've gone to far already to back out now! especially with all the bits I've got for it, so after a quick dig round the front floor, sills etc finding no further rust I decided just to carry on after all its only a little more welding! :hahaha:
Re: vitara sort out
Post by twiss » Sun Apr 27, 2014 10:45 am
I reckon it will be alright welding that bolt to the plate! Might make it a bit more difficult if you ever remove the body haha
Re: vitara sort out
Post by Anton » Sun Apr 27, 2014 4:22 pm
I've found a set of Vit calipers in my bits, but they're not stripped and reconditioned, so they may not be any better than the ones you have!
shredder
Re: vitara sort out
Post by shredder » Mon Apr 28, 2014 4:54 pm
no worries Anton cheers for looking :thumbup: not planning to remove body any time soon so should be ok :lol: now all I need is the weather to brighten up wet grass is no good for working on or trailing electricals across!!
shredder
Re: vitara sort out
Post by shredder » Fri May 09, 2014 6:36 pm
well what with weather and work not been near it for a while but an early finish and some sunshine today have helped
body mount welded in
done
and painted!
tomorrow I shall get stuck into the other side! :weld:
Re: vitara sort out
Post by Jordi » Fri May 09, 2014 8:30 pm
Nice to see the progress continuing. Some pretty tidy patchwork, presume you've sealed all the underside of them too?
shredder
Re: vitara sort out
Post by shredder » Fri May 09, 2014 9:05 pm
yeah clean them up and paint the underneath before welding them in, gonna under seal later on too ;)
shredder
Re: vitara sort out
Post by shredder » Sat May 10, 2014 2:46 pm
well that's the floor finally finished :armsup: working between the showers! got it done just before one almighty downpour!
as you can see its not quite as bad on this side
got all my essential tools close by :D
bit more patches than I woulda liked but what the hell, makes life easier
shredder
Re: vitara sort out
Post by shredder » Tue May 13, 2014 5:41 pm
well got the interior back in
sorted the hole in my bonnet was gonna weld in a patch but then thought bugger it its only the skin that's rusty so cut the rot out and used fiberglass
got home today to find my new grill had turned up :doublethumbs: so now can get on with making my new bumper
