changing fuel pump
Re: changing fuel pump
Post by Darrell » Fri Feb 27, 2015 6:51 pm
Anton wrote:Can you get injection tanks from gypsies?
Yes, but it would be made from paper mache with a bit of black paint on and you would never see them again :D
daemon982
Post by daemon982 » Fri Feb 27, 2015 9:13 pm
update :brows:
I changed my in tank fuel pump with self priming electric one. I mounted it in engine bay and it works great.
I just disconnected in tank fuel pump relay. So that the (in tank) pump doesn't engage :thumbup:
daemon982
update :brows:
Post by Anton » Fri Feb 27, 2015 10:35 pm
I think out-of-tank pumps are probably the only way forward. OEM injection pumps are so rare!
Just thinking out loud here though - what about an injection Vitara or GV fuel pump?
Post by ScottieJ » Sat Feb 28, 2015 12:39 am
daemon982 wrote:update :brows:
Most fuel pumps are designed to push fuel so should be mounted as close to the tank as possible, it'll be working a lot harder being mounted in the engine bay.
Post by Anton » Sat Feb 28, 2015 12:57 am
Yeah, I mounted my (low pressure, for a carb) electric pump on the chassis rail just ahead of the fuel tank for that reason. I don't know if it's standard, but there was a fuel filter there on mine, so I just fitted the pump there in line with the filter. Didn't have to cut any pipes or anything.
daemon982
Post by daemon982 » Sat Feb 28, 2015 6:18 am
the pump i got is designed to be mounted in engine bay or close to the tank.
This are specs and some data for the pump:
Technical Specifications:
Voltage: 12V
Connections: 8 mm
Capacity: 110 liters
Suction height: 1.0 m
Pressure: 0.20 bar
This diaphragm pump is similar to the known Mitsuba- fuel pump, which automatically adjusts the delivery rate of the consumption of the engine. During high-use it pumps quickly, with low consumption to pump slowly or not at all, making it ideal for carburettor systems up to 100 hp suitable.
Post by Anton » Sat Feb 28, 2015 9:02 am
I thought that injection models needed a high pressure pump?
daemon982
Post by daemon982 » Sat Feb 28, 2015 10:02 am
I'm running a carb model vitara 1.6 8v. so it's not EFI.
Post by Anton » Sat Feb 28, 2015 11:35 am
daemon982 wrote:I have a Samurai 1.3 8v single point injection model (1995), does this model have fuel pump in the tank?
daemon982 wrote:I'm running a carb model vitara 1.6 8v. so it's not EFI.
:er:
